Spitfire What hoses go where...
FlyingCat
I am just a paycheck away from putting a battery in my 1980 Spitfire (Federal). I've installed a Weber DGV carburetor. I got the radiator bracket back from the fabricators, and it's a perfect fit. (By the way, if anybody needs those radiator brackets, I have the plans for them.) I've put on the Hayden fan, and I should be able to wire that up without a hitch (thanks to everybody who helped me with that). But I still have a few things I can't figure out.
OK... I still can't figure out how to keep this program from rotating my pictures, but I can work around that. That's the carburetor. See the tube just to the right of the choke? The folks at Redline told me that was the vacuum advance, but since I don't have a vacuum pump (yeah... try finding one of those), they said I could just plug that up with a small rubber "cork." Is that correct? Or is there something better I can do here? Moving on...
See that tube coming out of the rocker cover? I think that originally went to the carbon cannisters, but I won't have those, either. Regardless, should there be a hose on that, and if so, where does it go?
And, finally (this time without pictures), there is a gas return tube on the carburetor. I asked the tech folks at Redline about that, too, and they said that I could just plug that, so I used the plug they provided. However... (there always seems to be a "however") ... there is a vent hose going from the gas tank to a carbon cannister (which I have), located in the back with the gas tank. Then there is a line going from that cannister heading to the front of the car. Only it doesn't get there. It stops about half way, leaving the end of that line open. I think that it originally went to the front where it hooked up with the carbon cannisters there. Like I said, there are no carbon cannisters up front anymore, and there's not going to be. So do I need to do something with that hose? Could it be the gas return? Do I need to plug it? Or does it need to be left open as is?
That's all I have for today, but that's enough. Thanks already for your help!
TR3driver
Great Pumpkin - R.I.P
Vacuum advance has nothing to do with a vacuum pump. (What vacuum pump? Do you mean the smog pump?) IIRC you have an earlier distributor (not the 1980 version). If it has provision for vacuum advance, then I would hook it up. Doesn't do much for performance, but saves some fuel under normal driving conditions (cruising). If not, then a simple cap over the port will do (any FLAPS will sell you a vacuum cap in a suitable size).
Might be worth checking first that the port is really setup for vacuum advance, though. That pipe looks kind of big, vacuum advance ports are usually smaller. If it is an advance port, it will lead to a small opening in the carb throat, just slightly above where the throttle plate sits at idle. Or another way to check is to put your finger over the port with the engine idling. If you can feel a strong vacuum at idle, it is not a vacuum advance port.
The port on the side of the rocker cover is the crankcase vent. It needs to be open to the atmosphere, and oily air is going to come out. Ideally, it would go to a catch can or similar; but I have been known to just hang a length of hose on it and let the hose hang down near the road; so the engine compartment doesn't get painted with oil mist.
The thing in the back is probably not a carbon canister, but rather a vapor separator (to keep liquid fuel from being forced forward to the carbon canister). That line is effectively the fuel tank vent. It will breathe fuel vapor under some circumstances, suck air in other circumstances. With no canister up front, might as well leave it open under the car.
poolboy
This is often the way the valve cover is vented on those downdraft Webers.Weber vent valve 2.jpg
FlyingCat
FlyingCat
I'm supposing I mean the smog pump. Just showing my ignorance there... but I'm learning! I'll check out my distributor, but I don't think it does. I'll probably end up capping it. Good to know it's nothing that the car won't run without. I like the idea of hanging a hose off the crankcase vent. All told, you answered my questions. Thanks!
Joe Schlosser
Vacuum advance connects to the distributor.
poolboy
If your engine is typical in it's accumulation of crankcase pressure, it's going to need a little help in the form of SUCTION on that valve cover hose in order to relieve the pressure...If you begin to see oil coming from seals around the crankshaft and joints on the engine, such as where the head meets the block following a spirited drive, you'll see why I say that.
FlyingCat
FlyingCat
You're exactly right! I found the thingy on the distributor where the hose goes, and then connected it to the carburetor. Smooth as Marvel Mystery Oil.
T MGB MGB hoses MG 6
T TR2/3/3A TR3 coolant hoses Triumph 2
alexisrexx TR6 Engine Hoses Kit or Hose by the foot? Triumph 6
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
Michael Oritt Brake hoses Austin Healey 10
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
S TR2/3/3A source for those little drain hoses Triumph 6
S TR4/4A Plenum Drain hoses Triumph 4
F What SS brake hoses do you recommend? Austin Healey 5
PatGalvin TR2/3/3A Coolant System Hoses Slipping Triumph 5
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
catfood Radiator Hoses Austin Healey 10
vette Colapsed Hose or Hoses Austin Healey 11
sparkydave Coolant hoses Spridgets 5
Griz Heater hoses Austin Healey 9
T TR2/3/3A replacement brake hoses Triumph 2
steveg Sourcing Custom Caliper Hoses Austin Healey 2
drooartz General Tech Check those brake hoses! MG 11
P Bugeye radiator hoses? Spridgets 5
GBRandy Wedge BOOM - check your hoses Triumph 15
N TR4/4A PCV hoses Triumph 5
D TR4/4A TR4A cooling hoses Triumph 2
RJS TR4/4A Replacing front brake hoses Triumph 10
B Replacement of Heater hoses Austin Healey 13
T TR2/3/3A TR3b temp gauge and heater hoses Triumph 10
M TR4/4A TR4A heater hoses Triumph 3
drooartz Any tips for replacing brake hoses MG 16
98Redline BJ8 Stainless Braided Brake Hoses Austin Healey 8
Darrell_Walker Wedge TR8 hoses, thermostat, etc Triumph 2
W TR6 installing heater hoses '74 tr6 Triumph 1
hondo402000 getting rid of my oil cooler, hoses, thermostat Triumph 2
BlueMax Silicone hoses kits down flow radiator Spridgets Spridgets 1
B GT6 GT6 heater hoses Triumph 6
PatGalvin TR2/3/3A TR3A Radiator Hoses Triumph 13
B TR6 TR6 Oil Cooler hoses Triumph 1
RonnieMac Vapor canister hoses MG 0
af3683 TR2/3/3A TR3 Heater Hoses Triumph 4
BobbyD Bad Coolant Hoses Triumph 11
B BJ8 Radiator Hoses Austin Healey 4
GBRandy Wedge TR8 A/C Hoses Triumph 11
B Wedge TR8 Hoses? Triumph 9
CinneaghTR Who makes the best TRactor motor cooling hoses? Triumph 4
bigjones Recommendations for radiator hoses - 1500 Spridgets 8
DNK Wedge Wedge PS Hoses Triumph 0
V Best radiator hoses? Spridgets 4
T Stainless steel brake hoses - two questions Spridgets 13
S TR2/3/3A tr3 front brakes hoses Triumph 9
A HIF4 Carb Vent hoses? MG 3
A new radiator hoses Triumph 1
tony barnhill '63 Midget Oil Cooler Hoses Spridgets 5
