Phase 1, Phase 2, Where's Phase 3
AngusSaunders
I've clawed through the search feature, quized the internet and have yet to understand the variations of the Mark III. I've found references to door pulls and park/ turn signal lights. There is even some ambiguous mention of suspension upgrades. Is there no phase 3 because there was no more upgrades? I see lots of references to the different phases but little information on what the differences are. My best guess is I have a Phase 2, manufactured in 64 and sold in 65.
Appreciate any explanation; Angus
Editor_Reid
Platinum
Hello Angus,
Briefly, the names Phase 1 and Phase 2 are not official model names. They're just shorthand nicknames to identify the early BJ8 cars (the so-called "Phase 1") with a rear suspension that rides lower and has pull-type door handles (as opposed to push-button style) and a "cubby box" (small storage box) on the center armrest. The Phase 2 BJ8 cars have a raised rear suspension that was BMC's crude attempt to decrease the problems with bottoming out, dragging the mufflers on the road/driveway surface. At the same time they also introduced push-button door handles that you may or may not like better, and they eliminated the storage box on the center console, a change that most people considered a loss.
The Phase 1 cars are chassis numbers 25315-26704 (1,390 made from November 1963 to May 1964).
The Phase 2 cars are chassis numbers 26705-43026 (16,322 made from May 1964 to December 1967, with one more car made in March 1968).
Many people actually prefer the aesthetics of the Phase 1 because the rear ride height looks natural, whereas the rear of the Phase 2 cars looks unnaturally "jacked up."
There is no such thing as a Phase 3.
A
AngusSaunders
Appreciate it Reid,
If I understand correctly, the phase 1 was made for near half a year and everything after that is considered phase 2. Was the modification to increase road clearance a frame modification or just suspension?
Angus
pkmh
I hope I am accurate to indicate other destinctions here between the Phase 1 and Phase 2 such as, and without getting too specific which includes, modifications and added working 2nd installment of the rear brake light markers (and larger), addition of second set of light markers in the front (and larger), reflectors added to the rear chrome bumpers (I believe was for the Phase 2, only), and I know the Su Carburetor setup went from HD6's to HD8's, but not sure and maybe someone else can confirm that the HD8's also were part of the Phase 1 development as well. What else did I leave out?!
Appreciate it Reid,
Angus
The P2 had radius arms to the axle, and I think the P1 still had a Panhard rod. The P2 had a dip in the chassis so the axle could ride lower (hence the body could ride higher):
https://www.healeywerks.com/gallery/preview.php?id=1549
A
AngusSaunders
I'm not so sure the front marker lamps are an indication of a Phase one or two. I see a lot of 65's with one on each side as mine has but by the chassis number mine is a Phase 2. There were probably minor changes to the phase 2 as the years progressed that didn't warrant creating a new category.
Angus
Editor_Reid
Platinum
Angus
Correct.
Anders Clausager's book, Original Austin-Healey, lays out the change points for running production changes. If you're interested in such minutiae - and many of us here are - I recommend you obtain a copy.
Keoke
IMO the raised height was all about the US standard bumper height being phased in. See also MGB, XKE and Alfa Romeo GTV among many others.
No Steve :
It was because the Germans did not like all that noise from the exhaust system, the were a big market, and that was the method used to make room for the rear resonators N quiet
it down.
steveg
No Steve :
it down.
Au contraire, Keoke -
All BJ8s came with the crossover exhaust (see Anderson Moment, p 145). So, while the Germans may have had a hand in quieter exhausts, it was a separate issue from raising the car on the Phase II, which also happened on a number of older designs when the US regs came out.
So it was likely a combo of scraping the mufflers and the bumper height regs.
John Turney
Those regulations came in 1968. One of may reasons Big Healey production stopped with 1967, except for one car for the home market.
Keoke
OK, another question. Is the frame on the Phase one the same as those on the earlier 3000's?
Angus
Very similar:
The rails were straight end to end
Keoke
Yeah:
I think U guys are right
Editor_Reid
Platinum
OK, another question. Is the frame on the Phase one the same as those on the earlier 3000s?
Angus
I know this isn't exactly what you asked, but to clarify some of the discussion on this subject and quoting Geoff Healey now on the difference with the "Phase 2" frame: "The top of the frame under the axle was cut away and lowered by 1½-inches. The top was closed in and the bottom lowered and strengthened at this point. New springs, raising the car by one inch, were fitted front and rear. The increased rear axle movement enabled lower rate springs to be used with benefit to ride and handling."
Additionally, among the other Phase-1-to-Phase-2 changes was elimination of the old Panhard rod, which limited the rear axle’s movement, replaced by two radius arms similar to those used on the early Sprite, while a revised exhaust system was installed to take advantage of the additional ground clearance.
The changes were in response to the long-standing complaints about the Austin-Healey's low ground clearance. They were not a response to regulations.
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY 1967 Mark III, Phase I through III and counting Austin Healey 38
B BJ8 Phase 1 Electrical Diagram Austin Healey 21
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
Fortius For Sale AH 3000 MK III Phase II 1967 - Denis Welch Engine & Parts Austin Healey Classifieds 0
R Healey Distributor Cap, Phase 2 Austin Healey 2
AH67 Phase one or Phase two bj8? Austin Healey 4
D Phase 1 or 2 Austin Healey 37
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
R Ignition Timing Issue, Phase II Austin Healey 8
Gearhead_Garage BJ8 Phase I Console Help Austin Healey 2
D Seat belts on a BJ8 -64 Phase 2 Austin Healey 20
B Front springs for phase 11 BJ8 Austin Healey 1
Bob McElwee '66 BJ8 Phase III Top Frame Assembly Austin Healey 3
Patrick67BJ8 Photos Needed of Front Wiring Routing - BJ8 Phase 2 Austin Healey 11
Patrick67BJ8 1967 Phase-2 BJ8 - Front parking & turn signal lights alignment Austin Healey 8
philman EVO Phase 1 Racing 2
P BJ8 phase 2 rear leaf springs Austin Healey 2
1 Phase 1 or 2 Austin Healey 2
S bj8 mk 3 phase 2 dash board Austin Healey 2
GregW Saw a Healy Phase 2 Today Austin Healey 12
S owoowbj8 mk 3 phase 2 Disc Wheels Austin Healey 4
AUSMHLY BJ8 phase one color wiring diagram Austin Healey 12
MadRiver Ruminations on the Phase 1 BJ8 Austin Healey 3
SilentUnicorn phase converters Restoration & Tools 15
M Finished Phase I of my MG project-pics... MG 9
J Armrest section of console for BJ8 phase 1 Austin Healey 1
Mark_Gibson Next Phase Complete, TR-2 has Body OFF! Triumph 6
gsalt57tr3 1953 Standard Vanguard Phase II Other British Cars 0
N Checklist? 3000 Mark III Phase II Austin Healey 8
J 1964 BJ8: Is it a Phase 1 or Phase 2? Austin Healey 4
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
