TR2/3/3A Where's the horn ground?
Jim_Stevens
Morning, Men:
Can someone tell me where the ground for the horn goes after it comes out of the trafficator? I have an intermittent horn, with both hi and low tested sat. Horn will work strong and fine one minute, but not at all the next. The 12-V bullets I shined up, but the wire for the ground side comes out of the trafficator tube and "disappears" into the engine compartment. I've already shined up all the grounds that are on the body just aft and outboard of the two horns. Full disclosure- I have the Bastuck slip ring unit for my R&P steering...
Does the the trafficactor itself ground it out when the button is pushed?
I hate to run around w a bad horn, since I have had to use them in earnest..... Jim
Geo Hahn
Are you referring to the brown/black wire? On mine all wires from the steering box run as a wrapped bundle to that confusion of wires at the top front of the left wing:
The brown/black wire emerging there goes into a female double bullet connector to join it to a pair of other (possibly larger) brown/black wires - one for each horn.
But since you have added a slip ring then your arrangement may be different or even unique to your car - but I would think the principle is the same: a ground controlled by the horn button that provides a ground to the always-powered horns.
doc50
Off topic, sorry:
Geo, what are the two downward facing round thingies in front of the lower radiator shield?
Geo Hahn
...what are the two downward facing round thingies in front of the lower radiator shield?
Those are two pieces of bar stock I use to mount an air dam. I had a pair of crutch tips over then as I worked to minimized the damage when I bang my head into one.
Here's the air dam in place:
And a look at a bracket:
The idea is to throw air at the lower third of the radiator as it is more or less out of the usual sir flow.
TR3driver
Great Pumpkin - R.I.P
Just a thought, Jim, a lot of my horn problems proved to be a bullet sleeve that was broken inside the vinyl sleeve. Just like yours, it would work sometimes (almost always when testing in the driveway) and other times not (always when I was trying to warn someone I was in the spot they were moving into).
I even added a relay, thinking the old contacts in the trafficator head were the problem.
Frank_D
I had a similar problem a few years back. Tried everything including sounding the horn for a prolonged period to clean the contacts while out in the country. Had a lot of cows looking my way as I went down some back road. Finally solved my problem by tuning the horns IAW this Lucas Manual: https://www.vintagemg.com/articlepdfs/thorns1-2.pdf . If all else fails try this. I have never had a problem with my horns since the adjustments were made. Good luck.
Frank D.........
TS42756L
TR3driver
Interesting article, but it seems there are some typos (or OCR errors). I'm pretty sure that should be 8 amps for a WT618 horn rather than 3.
untitled_2.jpg~original
untitled2.jpg~original
CJD
I love watching some threads grow and grow...and the OP seems to have forgotten all about it.
Jim_Stevens
Jim_Stevens
Not at all! Those pesky day jobs. I tuned the horns already, and as I said shined up all the contacts. Still intermittent. I think fundamentally, the question is Does the horn button itself make the ground, or does it just switch and the ground wire come down the tube? Jim
2liter4cyl
Bronze
The wiring diagram shows the ground connection is right at the horn button. Some part of the steering shaft needs to be grounded. Le
TR3driver
The button grounds the wire that runs down the tube, to make the horns sound. The other side of the button is grounded to the steering wheel. I don't know for sure, but my guess is that the current flows through the upper part of the shaft, then the 'lantern' springs and to ground through the lower part of the stator tube, it's compression fitting, and the steering box housing. Hopefully they don't rely on the steering box to ground the shaft through the bearings and/or peg.
M Where did my horn go?? Spridgets 4
saabmp3 Where is my horn button? Spridgets 2
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
FlyingCat Spitfire What hoses go where... Triumph 6
A Phase 1, Phase 2, Where's Phase 3 Austin Healey 14
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
Got_All_4 TR6 triumph tr6 wrist pins where to get them Triumph 5
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
R J-H Stromberg carb connections? Where do they go? Other British Cars 2
Paulus General TR Where to get HVDA parts and vibration when engaging clutch. Triumph 13
B TR2/3/3A Where on the clutch pedal? Triumph 4
N Spitfire Just picked up this 73 Spitfire. Hasn't run in ten years. Where do I begin? Triumph 10
P T-Series Where's my last TD? MG 2
R engine removal- where to connect hoist? Austin Healey 16
C Where and how to "disconnect" my two SU's? Austin Healey 3
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
S TR4/4A Where do the ground straps connect Triumph 5
Jim_Gruber Hubs a Rocking on side where Speedi Sleeve was installed Spridgets 5
warwick-steve Where did the smell go? Austin Healey 11
Gliderman8 TR6 Convertible cover snaps... where to install? Triumph 2
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
C Gauge faces - where to get Austin Healey 9
G Where can I get bottle jack seals? Restoration & Tools 2
R TR4/4A Where can I get Triumph Midnight Blue carpet? Triumph 0
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
C Where to wire a Pusher fan - BN1 Austin Healey 16
Rob Glasgow Brackets, where do they go? Austin Healey 3
Got_All_4 TR2/3/3A Where can i get these door handle parts Triumph 1
M BT7 restoration, Where to start and sill reinforcement Austin Healey 3
M TR2/3/3A Two black wires on control box E where do they g0 after alternator conversion? Triumph 9
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
