Muffler/Ground Clearance
Alan W.
Member
I have approximated 2 1/2" clearance from the muffler to the ground and was curious if there is a thinner profile muffler available. Car is a 59 bn6 (not lowered).
Thanks,
Alan
nevets
The muffler ground clearance on my BN6 is about 3 1/2”
BoyRacer
On my 1960 BT7 I have 3-7/8" clearance. My muffler is a stock replacement Wagner muffler. I am running Michelin XAS 180 HR 15 tires.
A
Alan W.
Member
Thanks for your responses. On further inspection it appears that the flex pipes from the exhaust manifold are too long and results in the front of the muffler being low. If I adjust the flex pipes then the mounting brackets don't line up. I will attempt to shorten the pipes. There is a welded-on solid end.
Alan
Michael Oritt
Like Richard (Boy Racer) I have been able to increase normal clearance to right about 4".
1. I run Michelin XAS 180's which are a bit taller than most others commonly used.
2. I reworked the manner in which the muffler is hung, so that it is as tight as possible to the underside of the driver's floor (after adding a layer of heavy Dynomat).
3. I also reworked the manner in which the pipe passes below and beyond the dogleg frame member--which is usually the tightest ground clearance spot on our cars.
I had planned to attend Conclave in Florida in 2020--which of course was cancelled due to COVID--possibly taking the AutoTrain down (to increase my odds of arriving without issue or drama) and then leisurely driving back up to Maryland afterwards. To guarantee the car's admissibility onto the AutoTrain--whose requirement is, I believe, 4" minimum with its driver at loading (even allowing for a pessimistic inspector and a fat guy driving)--I installed a short SS coupling or cuff at the exit of the muffler that allows me remove the tail pipe ahead of the rear tire and put on a side exhaust, thus eliminating the "knuckle" under the dogleg which results in a solid 4-1/4" to 4-1/2" clearance with driver aboard. The section of tailpipe will just fit into the car even with the hardtop in place. I hope to attend Conclave in 2023--again planned in Florida--next Spring.
I'd attach photos now, but am still recovering from pneumonia. We'll probably be blabbing about this for another week or two so I'll post some pics when I feel better.
BoyRacer
Alan, check the orientation of the front muffler mount that is bolted to the floor pan. This can be reversed. If it is reversed, the tab that the muffler is bolted to will be too far forward - by about 1-1/2" - and would make your down pipes too long.
Michael, Sorry to hear you're ill. Bummer.
Tail pipe swap solution for a 6 cylinder car? I decided to drive 400+ miles down to Califoria last month to a Healey meet. Since I had side pipes that would be too uncomfortable for any long drive, I swapped everything out for new fabricated down pipes (I have headers), a new Bell muffler and new tail pipes. After I slipped my new tailpipes into the muffler outlets ( I think they went in about 3") and bolted up the tail pipe mounts, I thought to myself, why should I put clamps on those unions? What if I want side pipes for next summer's driving around town? I really do like side pipes - just not on long drives. So I didn't use any clamps and everything seems to be fine. Nothing loosey goosey. Next summer I should be able to slip out the tail pipes and slip in some new side pipes for that around-town driving. And vice versa for the long drive to that Healey meet up in Canada next summer.
A
Alan W.
Member
Richard, I will check the clamp orientation. Thx. The car had a total restoration (kind of), and this is the type of thing that happens when a restoration is done by shops not familiar with AHs.
A
Alan W.
Member
It appears that the non flexible part of the front pipe off of the exhaust manifold comes down too low, I don't see a fix except proper replacement.
Alan
BoyRacer
What does the motor mount look like on that side?
AUSMHLY
Alan
I had the same issue when I got my mild steel ones from Moss. Where the pipe bolts to the manifold, 1" down, I cut about 1" off, had it welded back together. Don't see the modification. That fixed that issue. If you choose to do this, measure what's needed.
I don't believe remanufactured exhaust systems are as well fitting or sounding as the original.
Some modifying or changing of the mounting parts can also help raise the system. Example if a stock bracket is 1 1/2" and you have space, make it 1" (unless concours minded)
Just ran out to take photos, sorry, cars on jacks.
S TR2/3/3A tr2 muffler clamp Triumph 10
KVH General Tech Improvement to TR4A Muffler Triumph 1
B Muffler Construction Austin Healey 2
HealeyPassion Reducing Muffler Heat Austin Healey 2
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
M Muffler Options with Exhaust Header Spridgets 1
FredApplerot For Sale Pace Setter muffler for 1964-74 Spridget - Brand New Spridgets Classified 5
steveg Repacking the muffler Austin Healey 58
Healey Nut Muffler bearings Austin Healey 5
T Which Harley-Davidson Muffler for a BE? Spridgets 3
Steve P. Side exhaust, which muffler? Spridgets 9
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
T Rattling stainless muffler Austin Healey 10
I TR6 Muffler suggestions? Triumph 6
W Good price on Pacesetter Monza Muffler Spridgets 0
D BJ8 muffler on a BJ7? Austin Healey 6
R muffler advice? Spridgets 76
DanLewis One or two muffler configuration on a 1275? Spridgets 16
M TR4/4A TR4A muffler hanger to cross member attachment Triumph 13
G Anatomy of a Harley muffler Spridgets 63
Morris Opinions on this muffler? Spridgets 11
5 front muffler mount to body Austin Healey 4
B Anyone need a Harley muffler? [NFI] Spridgets 7
B Spitfire Advice on Muffler for 69 Spit Triumph 5
JPSmit Header and muffler connected Spridgets 16
BugeyeNJ58 Harley Muffler Users - did you remove center plug? Spridgets 3
BugeyeNJ58 Put on Harley Muffler--now backfires?? Spridgets 26
drooartz MGB Does this MGB center muffler look right to you? MG 10
M Muffler Bracket Spridgets 4
BugeyeNJ58 Need a Better Muffler for 59 Bugeye Spridgets 5
CZ_Dave Search for Muffler bearings MG 12
Jim_Newman Yet another muffler question. Austin Healey 3
Rut muffler choice Spridgets 15
sqbsprite Today's Project-Harley Muffler Spridgets 25
T TR2/3/3A TR3 muffler clamp Triumph 20
glemon Thoughts on TR Exhaust/Muffler Options Triumph 3
Jim_Newman 3000 muffler design Austin Healey 1
KVH TR4/4A TR4A Muffler Removal Triumph 2
T AH Muffler used on other cars Austin Healey 4
T Muffler inlet/outlet pipe diameters [?] Austin Healey 3
I Bugeye exhaust stud length for muffler? Spridgets 2
I bugeye muffler attachement? Spridgets 2
W Location and size of hole for muffler bracket Spridgets 10
boxfullofyertoys Looking for a Harley muffler Spridgets 54
Michael Oritt Need muffler recommendation Austin Healey 16
S Monza Muffler Spridgets 14
S Looking for muffler shop in western burbs/chicago Triumph 5
SilentUnicorn Harley muffler Spridgets 16
W Monza Performance Muffler Spridgets 65
S BJ8 muffler system Austin Healey 3
