Header and muffler connected
JPSmit
Got a header for Ms Triss - so far am really happy, except I should have slapped some paint on it before I installed it. Let me say that a header is probably worth it just to make dealing with the two studs under the manifold. sheesh. Anyway, yesterday took a very loud car (with only the header on) to Hot Rod Scott's the local custom muffler guy. Man did they do a great job! quick, welding is amazing, put a flange on the header so I can remove things easily and it really breathes better - nice rorty sound too. I'm very happy.
cr*ppy pics I know but it was my phone in a hurry.
JPSmit
JPSmit
Oh and did I mention stainless! Oh yeah baby... stainless!
drooartz
Very nice!
I wish you well with your header -> head sealing. I'm trying to get the issues there with the Tunebug sorted out right now.
Your system looks very nice and very clean. Enjoy!
apbos
John-Peter and Drew;
I am going to be using a header on my car (B/E). Question are you using the hanger off the transmission.? I do not have one and they are rare as hens teeth.
Paul
JPSmit
JPSmit
Paul, you'll need to hear from Drew on that - mine is the 1500 engine.
apbos
Thanks J-P. Are there any connections caudal to the header, other than the muffler on your car? It looks very nice and you'll never have to worry about rust.
P
G
Oooow, your baffle pulls right out.
PUll it out JP and take it for a spin ~now~! :driving:
Hey, you got two of 'em, right?
Pull the one out of the second and cut off the end cap and just bolt that in. ( the end cap).
aeronca65t
JP-looks good. Let us know how the under-the-axle approach works. I have that on my MGB and the axle taps the exhaust on bumpy roads. I had to drop the muffler slightly to reduce the axle/exhaust banging. I'm guessing your's is designed so the limit straps prevent this, but I can't tell. I am considering building a loop over the rear axle this Winter, but the B is a different creature than the Spridget (#909 has it coming out under the door, so not an issue).
JPSmit
JPSmit
P
Caudal? Is this a typo?
JPSmit
JPSmit
Not going to - breathe better or not I don't want the car any louder than now.
drooartz
Paul
Yes, I do have the hanger off the transmission. My exhaust also goes under the axle, no issues with it hitting at this point.
Jer
ohhh that's pretty JP !
apbos
Doctor speak, sorry JP
Caudal.....situated near or directed toward the tail.
Dr P, DVM
JPSmit
JPSmit
Dr P, DVM
OK - next time SWMBO asks where that smell is coming from, I will say it is a Caudal odor.
They made it up of three pipes but it is only bolted at the header and the muffler - all else is welded.
G
Let's see how loud it'll be, for scientific reasons of course....
G
JP, if yours is loud now, maybe it has been altered. I don't recall a removable baffle when I worked at the H-D dealer in '96.
JPSmit
JPSmit
Didn't say it was loud, I said it was loud enough.
M Muffler Options with Exhaust Header Spridgets 1
W muffler to match the header for a 1500 Spridgets 1
K TR2/3/3A Using header wrap on a street car? Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Intake header crossover passage..... Triumph 4
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
P For Sale Weber carb/intake, header Spridgets Classified 2
J For Sale Header, hub caps Spridgets Classified 1
bugedd Free header Spridgets 0
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
Rut TR4/4A Header seal attachment Triumph 0
Rut TR4/4A Header seal Triumph 3
R TR6 tr-6 header Triumph 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
D TR4/4A General header question Triumph 6
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
tomshobby Header Rail Seal Spridgets 4
H TR4/4A Header Rail Assembly Triumph 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Jim_Gruber Looking for header and rear BE Top bars Spridgets 18
N Recommend a header? Spridgets 4
D BJ7-8 header seal retainer Austin Healey 3
Boggsy64 MGB Three port exhaust header? MG 6
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
V early BN4 question - top & header rail Austin Healey 3
B Header rail weatherstriping Austin Healey 6
G Long center branch header for 1500? Spridgets 0
L Tubular header to ss exhaust pipe Spridgets 12
Coyote1 TR6 TR6 Header Rail Question Triumph 4
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
JPSmit Header Question Spridgets 2
GBRandy Wedge TR8 Header Install Triumph 42
bthompson Hood header rail gasket Spridgets 9
glemon Best Glue for Header Rail Triumph 8
7 Spitfire Spitfire Header Triumph 6
JPSmit Header Question Spridgets 9
tahoe healey header rail cover Austin Healey 0
DNK Header Bolts Triumph 17
mjobrien Top cross section at the front header / bow Austin Healey 0
doates Spitfire Spitfire Windshield Frame Header Triumph 5
PSJ Hardtop front header seal Spridgets 4
T Back to original, cast iron header. Triumph 16
T Need exhaust header advice/source for Amos Triumph 49
PAUL161 Hap-- Exhaust manifold/header paint? MG 2
drooartz View of the header faces Spridgets 47
RJS Header/ Exhaust Manifold Wrap Triumph 2
drooartz Question: washers for header->manifold Spridgets 5
