Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top
BG 62AH
Guys, I am hoping to get some advice on installing a new wooden header and side trim rails on my BJ7 convertible top frame. When I purchased the car, the top was in very poor condition, and all of the wooden pieces were severely damaged and rotten. The metal frame was the only part in relatively good condition, but needs to be repainted. I am finally at a point in my restoration where I am addressing the convertible top.
In addition to a new Robbins top, web material and seals; I have purchased all new wooden side trim parts and a new header rail.
I have searched the forum and found a lot of great information on how to replace the actual top, but there is very little on how to adjust and fit new wooden pieces. The top I will be using is identical to a BJ8, because my car is a "late" BJ7.
I did try to "trial" fit the wooden pieces. The header is pretty self explanatory. But positioning the side pieces properly around the windows so that they fit around the window and create a decent seal is less clear. I feel like they need to be re-shaped or trimmed a bit to match the shape of the windows. My parts came for AH Spares.
I would really appreciate any guidance on this.
Thank you very much for your help.
Bill
davidb
Hey Bill
Don't know how helpful this will be, but having said that, I ordered new side wooden pieces for a buddy's early BJ8 from Ahead 4 Healeys, and the fit was so poor that I returned them, with photos of my old ones to demonstrate how rough the fit was. Don't know who their supplier is, but obviously they weren't working from any decent blueprint. We ended up using the old pieces, drilling new wooden dowels into the old holes and glueing new wood into places where the old wood was rotted. We were quite pleased with the end result.
So if you've kept your old pieces you may wish to go this route. We just didn't have the tools to re-jig the new pieces to fit properly.
That's it, my friend. Good luck with your project.
DB
B
BG 62AH
David, thank you for the suggestion. I do still have all the old parts, but some are really dry rotted, and 2 are broken. The side pieces were not attached to the frame when I bought the car. I am certain that they are not repairable.
The parts from AH Spares seem to be of decent quality, but the contours appear to be a mismatch compared to the shape of the back of the roll up windows.
I am feeling like my best bet is reshape them with a belt sander. Was just wondering if anyone else had a similar experience.
i appreciate your response.
Griz
Bill, I can't offer you any advice at present, but I'm restoring my BJ7 and have just ordered new wood for the top (from Moss). Not to the place where I am working on this yet, but soon may be. Please keep us informed of your progress and any modifications/procedures you use to make them fit.
Griz
Open any picture in the album linked below; click on the opened picture will present the same picture in a new window, a second click on that pic will enlarge it to full resolution for greater detail.
https://spcarsplus.com/gallery3/index.php/reMKIII/top_work
I too was able to reuse these (BJ8) pieces, but maybe you'll get some use out of the pictures in the above link..
B
BG 62AH
Randy, these are a huge help. Thank you for posting them.
Johnny
Hi Bill, I too had lots of problems aligning the top frame. I had to adjust the windshield for elevation and the side mountings on the frame itself to get a good fit. It was one of the hardest problems I had. Here's some tips; Don't attach the top at the rear until your satisfied with the overall fit. Keep checking the window frames for correct fit. You can use washers to raise the side mounts, just don't tighten until sure of alignment. Oh, and yes you can bend the frame somewhat to fit properly.
Good luck.
B
BG 62AH
Thanks for this advice. I needed all new wooden components, and have resigned myself to reshaping the pcs around the door with belt sander. They seem to have come in oversized. I can see that I will need to do some tweaking with the windshield and frame, so your recommendations are a help.
Miktre
Hey Bill
I have just finished doing exactly the same thing apart from the new soft top. The old one was in a condition where it was reusable.
I replaced the top bow (across the screen) and all the side timber.
i had to rework all of the supplied timber (top bow from AH Spares and the side pieces from Moss). I used the old bits as patterns and then used a small air operated right angle grinder with a 50mm 100 grit Disk to sand - reprofile the new pieces.
Fortunately I didn't have to add any material, just sand it off. It would seem that to keep the cost down the suppliers have these bits CNC machined and they come out......kind off close but not exact. It did take quite a few hours but all good in the end.
I then took the side pieces to an auto upholsterer and he covered them in the correct vinyl.
Use an air powered staple gun when attaching the front of the hood to the top bow, the ash (I think that is what the wood is) timber is quite hard.
once the side timbers had been reprofiled and I was happy, I worked on the frame to try and get the side window gaps as little and as equal as possible. This did take days, as I would mount every thing and check it and then remove it all and use oxy actelene plant to heat and bend. I probably had the top on and off a dozen times or so. Once happy, I sent it in for powder coating to as close to the correct light grey as I could get.
I replaced the light grey straps with a safety belt product that cost me about $5.00 from a wholesale supply house.
I am vey happy with the final outcome
cheers
Mike
Miktre
Bill, Forgot to say that after the machine reprofiling there was a lot of hand sanding to about 400 grit I think.
The cut out area on the side pieces that allow the frame to sit well needed quite a bit of timber removal with a dermel and different bits and then sanding drum and then finishing with sand paper. I then sprayed it all with rattle can gloss clear epoxy from memory.
cheers
Mike
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
F Water pump replacement on my BT7 advice needed please Austin Healey 18
S Painting a BJ8 Radiator - any advice? Austin Healey 17
J advice on a 3 brush generator please C45N-3 Other British Cars 0
P Rechrome Advice Austin Healey 23
Bugeyze Engine mount advice please Austin Healey 9
S TR6 new TR6 owner looking for advice Triumph 9
R Factory Hardtop Restoration Advice Spridgets 2
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
Simmo TR6 CARPETS advice pleaese Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
davester Just got my Sprite back [in pieces] after 42 years...need advice Spridgets 8
M Tool Advice Sought Austin Healey 3
C Advice for installing a 3000 Grille??? Austin Healey 7
R Remove engine/transmission advice needed Austin Healey 4
I General TR Lower wishbone arm attachment bracket advice needed Triumph 8
BN6_2197 Advice on removing the float from the chamber Austin Healey 6
