Tubular header to ss exhaust pipe
lbcfan
This seems to be a problem.
I'm reusing a tubular header that I've had for years. It has a 1-1/2" female connection to the pipe.
My old exhaust pipe was 1-1/2" OD (mild steel), but a while ago, anticipating the rebuild, I purchased a Bell ss exhaust for the 948 that I had at the time. The thinwall tube is only 1-1/4" OD. I've done some research and I'm confident that the tube and straight muffler will give me the low enough backpressure and high velocity that will work well, even for a 1275. I've checked and the standard 1275 steel exhaust is 1-3/8" OD.
I also have a motorcycle exhaust set of bushings that gets me down to 1-3/8" ID on the header.
Problem is I cannot find a way to bridge the last 1/8" size difference to get to the 1-1/4" OD on the pipe. I've searched the UK sources and called local exhaust and motorcycle shops, and nothing seems to be available. By the way, I Emailed Bell and have not received a response. Disappointing...
Does anyone know a custom exhaust shop that could fabricate an adapter? I cannot be the only one to have run into this.
I would revert to the 1275 header, but the Bell front pipe is shaped for the 948 manifold.
Thanks for any sources,
Michael
aeronca65t
L
lbcfan
aeronca-
Thanks- close, but the 1-1/4" OD is actually too small.
Maybe I can offer a prize- all the unusable and extra parts that I will have left over from the restoration. The winner will have to send a truck...
Gerard
Michael,
Any decent muffler shop should be able to make this up for you. The usually have the machines to stretch or shrink the pipes. All you need is a short coupling.
Rut
Michael, Gerard hit the nail on the head. My muffler shop 'sweged' the muffler to fit the exhaust pipe, no adapter needed. They can do it for a slip fit or weld it.
Rut
L
lbcfan
Gerard-
I'm not sure what universe you guys live in. I read about all of these friendly local glass and muffler shops that look for unusual challenges. Around here (NJ) I have not had that luck.
I have called around. If it isn't a stock size, no-one is interested. I had bought an expander months ago- supposed to start at 1-1/8, but it won't fit into the pipe. I was concerned about stretching the thinwall ss anyway. It joined my pile of unused or never-will-be-used parts and tools.
If you know a shop in CA I would call them and have it shipped. Any source would be appreciated.
Regards,
Michael
JPSmit
Michael, not sure where you are in NJ but, I googled "custom exhaust" +NJ and got a number of hits. You are correct that most shops only care about what they have on the shelf but, they are out there.
Custom shops in NJ
Gerard
Michael,
I think as JP suggested already, you want to avoid the "big box" stores and try some custom or at least small. independent shops. In my "universe", there are places I can walk into like Sanderson Headers, but I use a small muffler shop in town for this sort of thing if I can't find an off the shelf reducer.
L
lbcfan
JP-
I've called a couple, including Mufflex in Camden. No-one goes down to 1-1/4". The best suggestion is to weld a larger pipe onto the end of the Bell pipe. That may be the way I have to go.
I've also found some slip-on chrome pencil exhaust tips in the UK that are meant to fit over the 1-1/4" pipe. If I cut one up it might create a bushing from 1-1/4" to 1/-3/8", which is what I need.
I know in the scheme of things that this is a very minor issue. I'll get it resolved.
Thanks,
Michael
JPSmit
Michael, have you considered getting a flange instead? wouldn't be perfect flow but it is another option & would be removable.
L
lbcfan
Problem solved. Found an adapter that has a 1-1/2" ID and 1-3/8" OD, at Advance Auto of all places. Expanded the 1-3/8" end slightly so that the 1-1/4" ss pipe "slipped" in, and butted the 1-1/2" adapter end to the header, with a 1-1/2" short pipe connecting inside. Looks streamlined and flow is smooth.
Thanks.
rkep01
Congratulations! I know the great feeling of accomplishment when you persevere and achieve your goal. Remember what Thomas Edison said - "Invention is 10% inspiration and 90% perspiration".:cheers:
L
lbcfan
Miracles enter into it. After searching the web for hours I found the little sucker laying in a bin at the store.$3 for the adapter and $30 for 3 chrome motorcycle exhaust clamps. Seems right...
blackdog Tubular exhaust manifolds Austin Healey 9
KVH TR4/4A Tubular Headers/Pertronix for TR4 Triumph 12
K TR2/3/3A Using header wrap on a street car? Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
K TR2/3/3A Intake header crossover passage..... Triumph 4
CARSINC Please Identify this Exhaust Header Spridgets 2
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
JFS TR2/3/3A Exhaust Header Fitment Triumph 13
P For Sale Weber carb/intake, header Spridgets Classified 2
J For Sale Header, hub caps Spridgets Classified 1
M Muffler Options with Exhaust Header Spridgets 1
bugedd Free header Spridgets 0
MadMarx Wedge Custom Header IMSA TR8 Triumph 14
Rut TR4/4A Header seal attachment Triumph 0
Rut TR4/4A Header seal Triumph 3
R TR6 tr-6 header Triumph 0
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
D TR4/4A General header question Triumph 6
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
Joe Reed General Tech VHT Flame Proof Header Paint MG 17
tomshobby Header Rail Seal Spridgets 4
H TR4/4A Header Rail Assembly Triumph 2
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
Jim_Gruber Looking for header and rear BE Top bars Spridgets 18
N Recommend a header? Spridgets 4
D BJ7-8 header seal retainer Austin Healey 3
Boggsy64 MGB Three port exhaust header? MG 6
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
V early BN4 question - top & header rail Austin Healey 3
B Header rail weatherstriping Austin Healey 6
G Long center branch header for 1500? Spridgets 0
Coyote1 TR6 TR6 Header Rail Question Triumph 4
johnrip Wedge TR7 pacesetter header connection to stock exhaust Triumph 2
JPSmit Header and muffler connected Spridgets 16
JPSmit Header Question Spridgets 2
GBRandy Wedge TR8 Header Install Triumph 42
bthompson Hood header rail gasket Spridgets 9
glemon Best Glue for Header Rail Triumph 8
7 Spitfire Spitfire Header Triumph 6
JPSmit Header Question Spridgets 9
tahoe healey header rail cover Austin Healey 0
DNK Header Bolts Triumph 17
mjobrien Top cross section at the front header / bow Austin Healey 0
doates Spitfire Spitfire Windshield Frame Header Triumph 5
PSJ Hardtop front header seal Spridgets 4
T Back to original, cast iron header. Triumph 16
T Need exhaust header advice/source for Amos Triumph 49
PAUL161 Hap-- Exhaust manifold/header paint? MG 2
drooartz View of the header faces Spridgets 47
RJS Header/ Exhaust Manifold Wrap Triumph 2
