Best Glue for Header Rail
glemon
I am in the process of installing the convertible top on my TR250. I have never done this before and am reading the online manuals and directions in the Williams book and taking it slow because I know it is basically a do it once, do it right type of operation.
I am at the point where I need to glue to the header rail, what is the best glue to use, please if you have experience be specific as possible, brand etc. preferably something I can get at the local hardware or auto parts place.
I think you want something that takes a good initial hold but allows for some adjustment if needed. It seems like this will be pretty critical, both the glue used and the fitting, to getting the install right, so any help/experience appreciated.
The top install is pretty much the last major step of the restoration and improvements I am doing to the car, if we could just get some son and warmth I could finish up.
Thanks, Greg
Darrell_Walker
I used contact cement, the kind you can get at the hardware store. Doesn't meet your desire for something that can be repositioned. That was the last connection I made, I clamped the front down to the windscreen, pulled the tension in the top I wanted, and marked a line with chalk along the front edge. Then I used that line to install it with the top loosened up.
I only use a light coat of contact cement on the header rail. You won't need much if the rubber seal track is installed correctly. That way if the top loosens up after some use, you can remove and tighten up the top later.
Marv
Platinum
We've always used Weldwood contact adhesive, the stuff used to glue laminates to countertops. Same method of positioning as Darrell, too. Works great.
glemon
glemon
Thanks, I just brought some home (Weldwood contact adhesive) and then got here and read your post, must be fate. Now I just need a warm, sunny day, tried other methods of warming up but with limited effect in my 50 degree garage.
Haven't seen much of the sun on these parts in better part of the last two weeks.
DNK
DrEntropy said:
We've always used Weldwood contact adhesive, the stuff used to glue laminates to countertops. Same method of positioning as Dave, too. Works great.
:pukeface: :pukeface: :hammer:
I Best glue for rubber door panels? Spridgets 3
N Best carpet glue???? Spridgets 5
I What is best glue to use? Triumph 16
Stewart Best glue for dash? MG 7
mctriumph TR2/3/3A the best kinda folks Triumph 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
tr6nitjulius For Sale "SOLD" Winter projects: Upgrades 4Sale or Reasonable Best Offer Triumph Classifieds 0
AngliaGT MGB-GT The Best Laid Plans....... MG 3
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
J Best Aluminum Fenders? Austin Healey 3
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
G Best fuel option for a 72 Midget Spridgets 5
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
JPSmit some days your best tool is a credit card Spridgets 2
dripdripdrip TR2/3/3A Best place for tonneau & hood stick covers? Triumph 2
D The best place to get shocks rebuilt. Spridgets 8
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
BoyRacer Best-Sounding Muffler - Stainless Steel or Mild Steel? Austin Healey 9
W Best source for Bugeye front shocks Spridgets 3
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Bob Claffie Best cruise in of the year Spotted 8
longbridgehealey Best way in Austin Healey 2
B TR4/4A What really is the best clutch/bearing combo Triumph 4
N Best cam choice??? Spridgets 5
R TR2/3/3A Best day ever [so far] Triumph 1
C How best to restore red script on valve cover? Austin Healey 7
F Best $25 I've ever spent on my Healey - 2019 Austin Healey Concours Guidelines Austin Healey 0
FlyingCat Spitfire Which carburetor is the best? Triumph 9
T TR2/3/3A Where is best spot to check temp with infrared thermometer? Triumph 17
D Best little tube bender Restoration & Tools 8
N Best lube for a Datsun gearbox?? Spridgets 6
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
DornTRoriginal TR2/3/3A Electrical Wiring Best Practices Triumph 13
I General TR Best car cover Triumph 8
M Best Interiors Austin Healey 20
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
S Best Ethylene Glycol/Water Ratio to avoid overheating? Why? Informal Survey. Austin Healey 27
B best diff British Motor Corp 5
Boink Pre-War MG-TB wins best in class at Forest Grove Concours MG 7
T TR2/3/3A What is best way to flush engine after antifreeze got in oil?? Triumph 2
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
glemon Mercedes 450SL Best Car Ever Made? Other Cars 7
cpbol Best alternative option to sleeved thermostat? Austin Healey 9
MisterB Spitfire Best year for a Spitfire? Triumph 12
D TR4/4A Best SU overhaul service to use? Triumph 10
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
Gerald_Gordon TR4/4A Best carpet for TR4 Triumph 2
C Best Replacement BN1 Leaf Springs Austin Healey 5
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
