TR4/4A What really is the best clutch/bearing combo
bammons
Ok I have done the searches - read the Buckeye articles and everything else I can find. I am totally confused. Could somebody please give me some guidance for the best clutch/throwout bearing combo? I am not racing or autocrossing only the occasional "fun" driving. I would like a lighter clutch so if I go nuts and let my wife drive she would not struggle. Would like to get by without spending the money for the "Magic Kit" but if that is the solution then I will. One supplier has a Sach's kit with a knockoff Gunst bearing. TRF has OEM with a Koyo bearing. I have read that the pinned type fingers are better than the roller or other fingers on the pressure plate. I would like this to be smooth shifting, long lasting without undue pressure. Please - some advice?
TR3driver
Great Pumpkin - R.I.P
I'm afraid this is one of those areas where experiences (and opinions) vary widely. I run a Laycock pressure plate, B&B friction plate, and an original type RHP bearing. It was my choice for "best available", and has worked very well for probably over 100,000 miles. When I moved the OD tranny from my wrecked TR3A to my current TR3, I didn't even replace the friction plate!
IMO this all got started because people were selling the wrong pressure plate, and there was a time when RHP made a lot of bad bearings. The bad bearings are gone, and most likely so are the wrong pressure plates. But YMMV.
B
bammons
Randall - So you are running the original pressure plate and bearing sounds like. Currently it has a bronze sleeve and probably the original T/O bearing (not original trans). Also has the original style B & B pressure plate. Should I just slap a new B & B friction plate on and go? How long do pressure plates last? Some writers seem to think using the original is best. Car has roughly 84,000 miles showing.
TR3driver
Others will disagree, I'm sure. But if it has been working for you, I wouldn't change anything that cannot be demonstrated to be worn or defective. Put a load on the TOB, if it still turns smoothly, I would reuse it. Etc,etc.
B
bammons
The transmission/clutch is out as I am totally rebuilding from the frame up. I was hoping to hear about the Koyo bearing and some experiences of different clutches but I have not so I think I will order the OEM/Koyo setup from TRF as I trust them to have good stuff. I did read about others complaining about too much pressure, premature wear etc and was just trying to avoid that. There is so much written with different experiences it is hard to know what is good. I only drove the car home so have no experience with what was in it. Thanks for your reply.
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
G Really nice to see some people are posting here again! TVR 11
T MGB Quick question about something that don't really matter just want to know. MG 9
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
PC something really cool, and a Ferrari Spotted 11
A Setting Camber Really Off Austin Healey 13
JPSmit TBH I think this is really striking Spridgets 2
AngliaGT VIR $10 Entry Fee - REALLY? Racing 1
John Turney No Job is Really Simple Austin Healey 17
T Oil filter block plate - really? Austin Healey 13
HealeyRick Really Original Bugeye on BaT Spridgets 12
Jim_Gruber In need of a really loud horn Spridgets 13
JPSmit Spotted - well I'm really not sure what? Other Cars 8
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
steveg Really Getting Into one's Healey Austin Healey 17
BJ8Healeys This one really has me stumped! Spridgets 4
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
S Has it really been 3 years? Spridgets 2
PC A really nice TR6 and a ? Spotted 2
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
F Overdrive - working but not really working Austin Healey 14
T TR4/4A Okay guys-so how hard is it really to freshen up a TR4 engine? Triumph 31
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
Keoke A Really Great Car Austin Healey 0
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
7 Post-War Other All apart, really frustrated and not sure what to do. Triumph 15
W I really wanted these seat belts... Spridgets 2
B do car bags really work? Triumph 2
drooartz Off Topic It really needs to stop snowing... MG 19
S Fuel pressure Regulator is it really needed? Triumph 9
bill_powell A really nice evening's drive... Spridgets 21
B Really basic question FORUM Navigation Questions 2
RickB Weird DPO wires heating up really hot Spridgets 16
B Really enjoying the Bugeye this season! Spridgets 5
KVH Fiberglass "Hardner"? Really? Triumph 7
JPSmit Parking garage spot - REALLY lousy pics Spotted 6
jlaird Had this really nice drive Spridgets 7
I Bugeye bonnet gaskets - do I really need these? Spridgets 10
bugimike Whew! What a find! Really? Spridgets 10
RandallRK Birds in engine compartment [well, not really] Austin Healey 5
C REALLY fast British race car [circa 1971] Racing 0
M Do you REALLY need drain holes in the floor pan? Spridgets 3
JPSmit Oh Man, now I really need that lottery win Spridgets 5
T Almost looks stock - really nice build Triumph 8
bcbennett Do heat shields really work? Triumph 18
T Prothane bushings are really nice to work with,,,, Spridgets 9
