Really dumb question related to turning back wheel and drive shaft
MGNoir
I've had my Midget up on jack stands now for several months as I've been cleaning out the engine bay, repainting some things, rebuilding front suspension, etc. Wheels are off.
Today I was going to reset the timing and reinstall the distributor. So I put it in gear (4th), and went back and turned the rear axle via the brake drum to get it to the valves to the right spot. Except when I turn it, it just spins free - no rotation of the drive shaft. Same on both sides.
Isn't... (and this is where I'm feeling like I'm totally missing something)... isn't the drive shaft supposed to turn when I rotate the rear wheels?
PS
I should add that this car was drive-able before it sat idle. Nothing broken in the drive shaft.
PPS
For some time, I had it on jack stands on two sides of the axle housing, but just had moved it to the attachment point of the front of the leaf springs. Could this have stressed out the axle and caused something to snap?
aeronca65t
Like most cars, this car has an "open" differential.
When you put the car in gear, have both wheels off the ground and turn one rear wheel, the other rear wheel will turn backwards. This is normal and is a function of the open differential.
For more info, slide to about 3:00 in ~This Video~
M
MGNoir
OK, so... what you're saying is when BOTH are free to spin, and one gets turned, the other turns the opposite to compensate as it were for differences - and as a result, there's no prop shaft rotation? And if one wheel isn't allowed to spin, then turning the other will turn the prop shaft?
*edit* I attached one of the wheels and now I can see the rotation of the opposite side. W/o wheels attached I wasn't seening the rotation
aeronca65t
Yes. Exactly.
If you turned one wheel and had someone firmly hold the other rear wheel, the driveshaft would turn.
It's a clever invention that allows the rear wheels to both receive power but also turn at different speeds.
There are disadvantages with the open differential, such as the fact that it feeds more power to the rear wheel that has the least traction.
That's why some cars have a limited-slip differential instead of an open differential. But that's a whole 'nuther story. :friendly_wink:
StupidHippie Really dumb diff mount question? Triumph 12
jlaird Question really dumb maybe Spridgets 7
G TR6 tr6 - really dumb dash question Triumph 4
E A really dumb problem MG 27
D Since we are asking really dumb dash questions Triumph 4
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
G Really nice to see some people are posting here again! TVR 11
T MGB Quick question about something that don't really matter just want to know. MG 9
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
PC something really cool, and a Ferrari Spotted 11
A Setting Camber Really Off Austin Healey 13
JPSmit TBH I think this is really striking Spridgets 2
AngliaGT VIR $10 Entry Fee - REALLY? Racing 1
John Turney No Job is Really Simple Austin Healey 17
B TR4/4A What really is the best clutch/bearing combo Triumph 4
T Oil filter block plate - really? Austin Healey 13
HealeyRick Really Original Bugeye on BaT Spridgets 12
Jim_Gruber In need of a really loud horn Spridgets 13
JPSmit Spotted - well I'm really not sure what? Other Cars 8
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
steveg Really Getting Into one's Healey Austin Healey 17
BJ8Healeys This one really has me stumped! Spridgets 4
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
S Has it really been 3 years? Spridgets 2
PC A really nice TR6 and a ? Spotted 2
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
F Overdrive - working but not really working Austin Healey 14
T TR4/4A Okay guys-so how hard is it really to freshen up a TR4 engine? Triumph 31
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
Keoke A Really Great Car Austin Healey 0
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
7 Post-War Other All apart, really frustrated and not sure what to do. Triumph 15
W I really wanted these seat belts... Spridgets 2
B do car bags really work? Triumph 2
drooartz Off Topic It really needs to stop snowing... MG 19
S Fuel pressure Regulator is it really needed? Triumph 9
bill_powell A really nice evening's drive... Spridgets 21
B Really basic question FORUM Navigation Questions 2
RickB Weird DPO wires heating up really hot Spridgets 16
B Really enjoying the Bugeye this season! Spridgets 5
KVH Fiberglass "Hardner"? Really? Triumph 7
JPSmit Parking garage spot - REALLY lousy pics Spotted 6
jlaird Had this really nice drive Spridgets 7
I Bugeye bonnet gaskets - do I really need these? Spridgets 10
bugimike Whew! What a find! Really? Spridgets 10
RandallRK Birds in engine compartment [well, not really] Austin Healey 5
C REALLY fast British race car [circa 1971] Racing 0
