RandallRK
Member
It sure sounds like there are a couple birds in my engine compartment- there is a high pitched squeaking sound which comes from the engine intermittently. Any thoughts on what might be causing this would be welcomed.
The noises are not tied to the car moving as they can happen right after startup when the car is still. However, they are more pronounced/louder when in motion (and especially over rough patches). The pitch or presence of squeaking noise does not appear to be tied to RPM (ie. can happen at varying RPMs and does not necessarily get progressively faster/higher pitch with engine speed). Otherwise, this is a well running but mostly original Healey.
My guess for cause of noise at this point is perhaps the rubber blocks in the engine mounting points but that's just a WAG. Your guidance is appreciated.
