    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Really dumb diff mount question?
StupidHippie
My TR6 is showing no signs of having a diff pin problem...I am installing poly mounts just because of the age of the existing original mounts.
Assuming the pins are in sound condition, is it possible to drop the diff enough to change the mounts without disconnecting the driveshafts?
Rob Brophy
1974.5 TR6
Only the rear 2 and the lower front ones.
The extra stiff poly mounts do not absorb the stress from torque as well as the rubber ones.
That stress will be transfered somewhere else.
Perhaps showing up in the axle splines, or the mounting brackets and accentuate any slack or play that has developed due to wear in the differential. I just think they tend to make the diff. too rigid, unless all the rear end/suspension components are in tip top shape.
Thanks for the quick reply. I'll pull it all apart and have a looksee while I'm there.
I'm after longevity more than performance...saw the rubber mounts available and didn't like the look of them.
Rob
I don't know about the looks. They are definetly of a different composition. As far as longevity, 20 or 30 years is not exactly a temporary fix.
Rob Brophy
1974.5 TR6
<span style="color: #660000">Rob- if you figure out a procedure to do that-
please post it with photos. I had to take the entire differential
out of my 1969 TR6 to install new mounts. But then,
I know very little of auto mechanics.
d</span>
If I could buy original composition rubber mounts I would have.
I doubt the Asian manufactured mounts I saw would last a fraction of the original's 34 years. Are any of the parts sellers offering OEM mounts?
Rob
I don't know about that. The ones I got from Moss have only been on a little less than a year, so I don't think I could really compare to the old ones I took off.
Really the front ones, the old ones, weren't bad. I know that oil will deterioate rubber, but these looked OK. The rear ones were a little different. The metal inner sleeve had lost it's bond to the rubber and was more or less free floating. You could hear the metal sleeve clinking on the metal stud when the diff torqued up.
I hope they last as long as I have the car.
Poolboy..... I think I'm seeing that right now. Nylatron diff and TA bushings, Nissan 4.08 diff = clunky axles. My winter project is to sort this all out!
Yeah, I saw that on the other Forum, Bob. It got me remembering my reason for going back with the rubber mounts. Coincidentally Rob B brought up the subject here today, too.
I really think there's something to it. As you implied, the stress from the torque has got to be dealt with somewhere..
I'm thinking it's similar to motor and transmission mounts. They have to be flexible enough to absorb or give with stress.
Seems to me that the only thing more rigid than the poly mounts would be if the diff. were bolted directly to the frame.
That very reason that I pulled all the poly mounts out of my car's suspension and went back with rubber everywhere. It handles just fine with rubber.
Oh, and never buy the gum from the vending machines in the gas station men's room - it tastes like rubber!
TR6BILL said:
...Oh, and never buy the gum from the vending machines in the gas station men's room - it tastes like rubber!
And the balloons don't get very big
OK Poolboy...your reasoning has sold me. I've purchased the rubber set as well and will install them instead of the poly mounts. I'd rather change the mounts again in a few years than face a serious frame repair.
Tinster...If it can happen that way, I'll post pix.
Thanks all,
Rob
I installed the rubber mounts and after
a solid two years on the pins and 67 miles
total driven; they seem like new.
d :devilgrin:
M Really dumb question related to turning back wheel and drive shaft Spridgets 4
jlaird Question really dumb maybe Spridgets 7
E A really dumb problem MG 27
D Since we are asking really dumb dash questions Triumph 4
G TR6 tr6 - really dumb dash question Triumph 4
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
G Really nice to see some people are posting here again! TVR 14
T MGB Quick question about something that don't really matter just want to know. MG 9
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
PC something really cool, and a Ferrari Spotted 11
A Setting Camber Really Off Austin Healey 13
JPSmit TBH I think this is really striking Spridgets 2
AngliaGT VIR $10 Entry Fee - REALLY? Racing 1
John Turney No Job is Really Simple Austin Healey 17
B TR4/4A What really is the best clutch/bearing combo Triumph 4
T Oil filter block plate - really? Austin Healey 13
HealeyRick Really Original Bugeye on BaT Spridgets 12
Jim_Gruber In need of a really loud horn Spridgets 13
JPSmit Spotted - well I'm really not sure what? Other Cars 8
Got_All_4 TR2/3/3A Something is really wrong? Overdrive Tranny Triumph 7
steveg Really Getting Into one's Healey Austin Healey 17
BJ8Healeys This one really has me stumped! Spridgets 4
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
Jim_Gruber Dilema - Take it back apart or not - Slight and I mean really slight LF Wobble Spridgets 3
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
S Has it really been 3 years? Spridgets 2
PC A really nice TR6 and a ? Spotted 2
Wirewheels General Tech Do we really care what our LBC's speedometer reads? Should we? MG 7
F Overdrive - working but not really working Austin Healey 14
T TR4/4A Okay guys-so how hard is it really to freshen up a TR4 engine? Triumph 31
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
Keoke A Really Great Car Austin Healey 0
J MGB Need some Exhaust flange advice MGB< but really any of our old cars MG 0
bighealeysource How to color sand really bad orange peel Restoration & Tools 6
7 Post-War Other All apart, really frustrated and not sure what to do. Triumph 15
W I really wanted these seat belts... Spridgets 2
B do car bags really work? Triumph 2
drooartz Off Topic It really needs to stop snowing... MG 19
S Fuel pressure Regulator is it really needed? Triumph 9
bill_powell A really nice evening's drive... Spridgets 21
B Really basic question FORUM Navigation Questions 2
RickB Weird DPO wires heating up really hot Spridgets 16
B Really enjoying the Bugeye this season! Spridgets 5
KVH Fiberglass "Hardner"? Really? Triumph 7
JPSmit Parking garage spot - REALLY lousy pics Spotted 6
jlaird Had this really nice drive Spridgets 7
I Bugeye bonnet gaskets - do I really need these? Spridgets 10
bugimike Whew! What a find! Really? Spridgets 10
RandallRK Birds in engine compartment [well, not really] Austin Healey 5
C REALLY fast British race car [circa 1971] Racing 0
