How to color sand really bad orange peel
bighealeysource
Bronze
Hey y'all,
Fortunately this is not on my Healey but was trying to help out my daughter by replacing the rear plastic bumper cover on her 2008 Honda Civic. Got the base coat down nice but the clear ended up looking like a textured paint job ! Guess it was too cold and probably had pressure set wrong on the gun but it is what it is. I tried color sanding one area and can get it pretty flat but using 1000 grit will take me a lifetime. Do have the clear on pretty thick - also part of the problem - so should I consider removing most of it with maybe 400 grit and then go back to the 1000/1500/2000 grit process ? Hate to think about stripping it off so trying to salvage my poor clear coat job.
Thanks,
Mike
BigGreen
Since about a year there are denim pads (flexipads) available for polishing machines
They take care of orange peel in no time, faster than sanding
Be sure to use a thin / oily polish (like Meguiars) and not a relatively dry one
Bayless
You don't remove orange peel with 1000 grit. That's a job for 400 or a machine. If you are relatively inexperienced you need to be very careful with any machine though. They can cut through faster than you might imagine. Use a really light touch particularly on curved surfaces and stay away from any edges.
bighealeysource
bighealeysource
Bronze
Hey guys,
Thanks for your advice on what to do - appreciated it. Ending up having to use some 400 grit hook and loop sanding discs on my dual action sander/polisher to get it off. Now have it back to the original state so put a fresh coat of primer on and will shoot a new base coat this weekend. Then take A LOT of time and get the clear coat right before I shoot it onto the bumper cover. Will practice on some old sheet metal I have around to practice welding on.
Thanks,
Mike
Mad tiki customs
Actually you do sand with 1000.
Use a medium density block if a DA is not available.
400 is what we in the industry use to prep for paint. 400 will cut through the paint in a few short strokes. And if your lucky enough not to cut through the clear with something so aggressive, by the time you sand out the 400 scratches youll have no more clear left to polish.
If the paints that bad, i would knock it down with 600 and re clear it. Use 15% reducer and heat up the paint or bumper before hand. I use to use the home depot halogen work lights. Keep it about 1-2 ft away from the paint with the lid slightly opened for venting. Wait about 20 minutes and the paint will flow really nice.
Hope this guides you in the right direction. If you have any questions i'll be happy to help. Ive been restoring cars for almost 30yrs. Most of which are show cars. I'll be happy to pass on some insider tips :smile:
glemon
Not near as much experience as Mad tiki, but I would agree totally, if you are trying to preserve the top coat and eliminate the orange peel 400 grit would scare me to death, if you want to take it all off and start over it is fine, and sounds like that is what the original poster did, so maybe I misinterpreted the question, thought he was talking about taking off the orange peel, not refinishing. Hadn't heard of the denim pad, will have to try it next time.
A Paint Color Codes Austin Healey 0
B Cove Paint Color Ideas Austin Healey 10
F TR2/3/3A Headlight bucket color Triumph 22
P General TR What color is original for engine parts? Triumph 7
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
B TR6 Help with color and color code / paint recommendation Triumph 4
S 1958 100/6 Bumper Brackets Color Austin Healey 2
R Cooling Fan Color Austin Healey 6
B TR4/4A Dash Color? Triumph 3
B TR4/4A Gas Tank color? Triumph 4
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
R Speedo High Beam Warning Light Color Austin Healey 14
Rut TR4/4A Dash color Triumph 9
G Opinion on spark plug color Austin Healey 15
R TR6 Sapphire Blue color Match? Restoration & Tools 3
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
M Rear ended pumpkin color Austin Healey 6
T TR2/3/3A Chassis paint color Triumph 10
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
Johnny AH BJ7 Trafficator Color? Austin Healey 7
N Bumper bracket and fan shroud color Austin Healey 5
P TR2/3/3A TR2 color questions Triumph 23
HealeyRick Color Match Misconception Austin Healey 15
R TR2/3/3A Color Wiring Diagram-1954 TR-2 Triumph 1
I TR6 Gauge/color wire ? Triumph 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
B GT6 Chassis color Triumph 4
D TR6 What Color is This? Triumph 11
T BN7 wiring diagram in color Austin Healey 7
busybrit TR4/4A Steel dashboard color Triumph 1
T Austin Healey 100 engine color Austin Healey 10
Rut Bugeye generator color Spridgets 22
simon1966 100 X Brace Color? Austin Healey 16
F TR2/3/3A Wheel Color Triumph 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
J TR6 Paint color Triumph 22
simon1966 Eclipse Day Photos, back to her old color! Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
maxwedge5281 engine compartment color Austin Healey 2
R BT7 Brake Drum Color Austin Healey 7
busybrit TR4/4A TR4 Steel dashboard color Triumph 8
Jim_Gruber Paint Color - Black Satin or Black Glossy for Suspension components Spridgets 9
