TR2/3/3A Color Wiring Diagram-1954 TR-2
Redoakboo
I am restoring a 1954 TR-2 Long Door and am just about down to the re-wiring. Does anyone have access to a color wiring diagram? I have the black & white one out of the manual and took several pic's
of the back of the dash before I get started.I have seen a color one, but don't remember where?
Dick
TR3driver
Great Pumpkin - R.I.P
All I've got is this one from Dan Masters (which has had a couple of missing lines added). However, I think it is inaccurate in several small ways. For example, on early cars, the power to the heater control is supposed to come from the wiper switch, not the fuse block. The effect is the same (heater gets power from the green circuit), but the details aren't quite right. Also, the apparently original OD wiring on TS38781LO matched the factory diagrams, which show the operator switch on the supply side of the relay coil rather than the ground side. Either way will work, of course, but one is not original.
https://i.imgur.com/KrLiXuv.jpg
T BN7 wiring diagram in color Austin Healey 7
MikeAH100M BN1 Color Laminated Wiring Diagram Austin Healey 1
Boink Color Wiring Diagram for Mk1 Spridgets 8
tweety color wiring diagram, where to get one? Spridgets 18
P Color Wiring Diagram Triumph 7
AUSMHLY BJ8 phase one color wiring diagram Austin Healey 12
S Spitfire 74 Spitfire 1500 color wiring diagram Triumph 4
Patrick67BJ8 BJ8 Wiring Harness Color Austin Healey 12
J TR4/4A Correct color for TR4 wiring harness Triumph 5
R Wiring harness discrepency in color code. Austin Healey 2
danmas wiring diagrams in color MG 4
danmas wiring diagrams in color Triumph 15
78Z British Standards for wiring color codes Restoration & Tools 1
A Paint Color Codes Austin Healey 0
B Cove Paint Color Ideas Austin Healey 10
F TR2/3/3A Headlight bucket color Triumph 22
P General TR What color is original for engine parts? Triumph 7
BoyRacer Silver Healey - Chassis Color? Austin Healey 17
B TR6 Help with color and color code / paint recommendation Triumph 4
S 1958 100/6 Bumper Brackets Color Austin Healey 2
R Cooling Fan Color Austin Healey 6
B TR4/4A Dash Color? Triumph 3
B TR4/4A Gas Tank color? Triumph 4
A Color Matching Austin CU 50 "Dominican Blue" British Motor Corp 3
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
D TR2/3/3A center panel indicator light color Triumph 10
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
R Speedo High Beam Warning Light Color Austin Healey 14
Rut TR4/4A Dash color Triumph 9
G Opinion on spark plug color Austin Healey 15
R TR6 Sapphire Blue color Match? Restoration & Tools 3
Jayplum TR2/3/3A Starting from scratch what color Triumph 25
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
Jim_Stevens TR2/3/3A Finally- the color coat! Triumph 12
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
M Rear ended pumpkin color Austin Healey 6
T TR2/3/3A Chassis paint color Triumph 10
B Dashboard color Austin A40 Devon 1948 Restoration & Tools 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
Johnny AH BJ7 Trafficator Color? Austin Healey 7
N Bumper bracket and fan shroud color Austin Healey 5
P TR2/3/3A TR2 color questions Triumph 23
HealeyRick Color Match Misconception Austin Healey 15
I TR6 Gauge/color wire ? Triumph 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
B GT6 Chassis color Triumph 4
D TR6 What Color is This? Triumph 11
busybrit TR4/4A Steel dashboard color Triumph 1
T Austin Healey 100 engine color Austin Healey 10
