TR4/4A Dash Color?
bammons
Does anyone know of a proper color match in brown for the metal dash on a 65' TR4A? In spray can. Found where people discussed it being brown but no color references. Thanks Bruce
charleyf
I could be very wrong here, but weren't the TR4A covered with a wood veneer dash. If that is correct then the brown on the dash was a primer. Just a plain brown primer.
Charley
B
bammons
Charley - Yes it has a wood dash but I have cleaned up the metal dash underneath and just want to paint it back correct. I looked at Rustoleum "Expresso" and I think it might be close enough but I thought others might have something else in mind. Bruce
Popeye
Bronze
I used a generic brown rustoleum. Probably not concours, but you can't see any of it from the outside. (Or I can argue I matched the faded paint... :smile:)
Rut TR4/4A Dash color Triumph 9
Joe_Healey BN2 dash Color Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
simon1966 100 Dash Color Austin Healey 10
AUSMHLY Dash panel color scheme 1960 3000 Austin Healey 7
Frank C. BJ8 Dash Wood Type/Color Austin Healey 25
bighealeysource correct dash paint/color on BN1 Austin Healey 8
H 100 Dash Color Austin Healey 3
Z T-Series MG TD Dash Panel Color MG 15
HAN8L1965 65 dash color Spridgets 3
F Bugeye dash color Spridgets 5
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
EWD TR6 TR6 top dash trim paint Triumph 2
TomMull Dash wiring Plus 2 S Lotus 16
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
I TR6 Thickness of original TR6 dash Triumph 2
S TR2/3/3A Dash Pot Oil Triumph 14
TRMark T-Series Dash for Sports/Racer MG 5
