Rob Glasgow
This has been covered before but I would like to show you my solution. I ordered 10 LED E10 base bulbs in warm white from ebay. Took 3 weeks to arrive. Total cost $12.50 delivered. Installed 4 in the gauge lights and one in the turn indicator. The size of the bulbs fit perfectly, even the turn signal tube. You can see the results. I didn't do a 'before' photo, but if you've driven your Healey after dark, you know what that looks like. The bulbs look like good quality and the results are brilliant. You do get some leg light as a benefit..... As you know, the fuel and oil pressure/temperature gauge have a blue plastic lens around the edge which gives those gauges the tint.
