LED Instrument Lights
bighealeysource
Bronze
Merry Christmas all,
Got a weird problem installing some Moss LED dash/instrument light bulbs. Got one installed on the speedometer okay and works fine. Installing is just unscrewing the old 2 watt bulb and screwing in the new LED bulb. On the tach location the 2 watt bulb works, has power obviously, but when I screw in the LED get nothing. Checked to make sure the new LED was working and it is, but will not light up! Any ideas on this minor problem?
Thanks,
Mike
Tachs have two bulbs: backlight and charge indicator, which one are you referring to?
Supposedly, the charge indicator should not be an LED--it indicates a voltage differential between battery and generator--but I use one and it works fine.
re: "Checked to make sure the new LED was working and it is, but will not light up !"
A bit of a contradiction; if it works 'on the bench' but not in the car it could be a polarity issue; are you + or - ground? Pos. gnd. LEDs are a bit harder to procure.
bighealeysource
bighealeysource
Bronze
Hey Bob,
It's the backlight bulb and it is negative ground. Got one installed on the backlight for speedo as mentioned and it works fine.
Thanks
Mike
Gliderman8
LED's have to have the proper polarity to work.
Hey Bob,
Thanks
Mike
Did you swap the speedo light for the tach light? If so, what happened? Did you check the tach's ground with a voltmeter (or continuity checker)?
bighealeysource
bighealeysource
Bronze
Hey Bob,
No I hadn't tired either of those two but will ! I'll let you know as agree it does sound like a grounding issue. I checked on my Moss invoice and did get the correct negative ground bulbs.
Thanks
Mike
McTriumphs
Thanks,
Mike
Bad Ground.
bighealeysource
bighealeysource
Bronze
Hey y'all,
Well, it was as suggested, not grounded properly. The two wires from the small bulb holder were apparently reversed. Got enough juice to light up the small 2 watt standard type bulb but not the LED. Once I connected them back up the opposite way, LED works great.
Thanks for all the help,
Mike
bighealeysource
bighealeysource
Bronze
Definitely on the tach, not as much on the speedometer but now I can see the instrument faces at night !!!
They're definitely brighter but, because the sockets are at the bottom of the case the dials aren't illuminated evenly (brighter at the bottom).
EWD TR6 LED instrument conversion / Dimmer. Triumph 25
PAUL161 General MG LED Dash and Instrument Bulbs POS or NEG ground. MG 8
B instrument led lamps Austin Healey 12
PAUL161 T-Series MGT 7 inch LED Headlights MG 4
B Positive-Ground LED Light Strip Austin Healey 8
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
J LED lights for PL 700 Restoration & Tools 12
Guido36 LED Headlight Upgrade Austin Healey 1
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
BoyRacer LED Turn Signals Austin Healey 5
S TR2/3/3A LED turn signal -- panel flasher not working Triumph 5
P LED Brake Lights Austin Healey 2
B TR6 LED Headlights Thouights? Triumph 28
T Decreasing Intensity of LED Lighting Austin Healey 3
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
Michael Oritt LED bulb/resistor wiring question Austin Healey 24
johnrip Wedge TR7 led light conversion question Triumph 1
ckeithjordan TR2/3/3A LED Flasher Problem Triumph 13
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
Lukens TR2/3/3A Led flasher relay? Triumph 3
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
R TR2/3/3A Positive-ground LED lights Triumph 13
Martinld123 Just installed LED headlights in BN2 Austin Healey 15
Bob_Spidell LED Headlamps Austin Healey 14
Gliderman8 TR6 Correct LED flasher relay Triumph 6
N Charging warning light LED conversion Austin Healey 29
S LED or Quartz-Iodine headlights for my '67 AH 3000 Austin Healey 22
J LED Brake / Turn Signal Austin Healey 4
Martinld123 Problem Using LED lights with Existing Brake Lamps Austin Healey 20
Joe Schlosser LED Turn signals Austin Healey 9
Joe Schlosser LED flashers Spridgets 2
Gliderman8 General TR Let there be [LED] light! Triumph 18
D LED shop lights Restoration & Tools 10
GTP1960 TR2/3/3A LED headlight question Triumph 11
gbtr6 TR6 LED light bulbs questions Triumph 20
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
Marla TR4/4A Led dash lights Triumph 0
jfarris TR2/3/3A Moss LED Tailight Kit Triumph 4
P LED Dash Lights Spridgets 1
K TR2/3/3A LED dash bulbs again? Triumph 2
gbtr6 TR6 LED Dash Lights Triumph 8
D TR2/3/3A TR3 LED Lights? Triumph 5
G BJ8 Phase II conversion to LED turn signals Austin Healey 11
S LED Exterior Light Upgrade Spridgets 15
Scotsman TR2/3/3A LED headlights Triumph 4
