TR2/3/3A Switching to green LED dash panel bulbs?
karls59tr
Bronze
I installed green led bulbs in the speedometer and rpm gauges some time ago as I find that they are less bright for night driving. I would like to do the same for the dash temp,fuel,oil pressure and voltmeter but I'm not sure of the bulb sizes? I just found out that there is a place called classiccarleds.co.uk that should have them. I checked their PDF of the various makes but oddly enough they do not have a listing for Triumph??? Anyone know the size of these bulbs? Would I be wrong in assuming they would be the same as an MGA of that era? Any thoughts?
Hamish Racing
I think for these there are no bulbs “in” the instruments but sit in between and shine through slots in the instruments
Thus I guess you’ll need an led that has a wide spread of light.
as to what type I’m afraid I don’t know.
the led supplier you have a link to is very good indeed. Email them I’m sure they have an led for the job.
they do a great flasher unit if you change to led indicators / flashers. As the original flasher Relay can’t cope with LED’s
K
karls59tr
Bronze
I did contact them. Should have done that before posting here. The bulbs I need are GLB987 if anyone else is interested. They are the screw in type that fits the original bulb holder! I did not know anyone made those. Going to try them out. (y) (y)
Trevor Triumph
I've used an outfit called. "litezupp" or some such thing. I have red and amber LEDs for running lights and turn signals, a bright white for license plate and panel lights. I never considered green IP lights, but it seems like a good idea.
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
M od switching on and off on freeway Austin Healey 4
R 5mm wheel spacers on front when switching Minilite Triumph 2
bighealeysource switching out brake fluid from silicone to Castrol Austin Healey 4
M Project started-switching dash Spridgets 17
M_Pied_Lourd Switching Gears..... Triumph 18
Got_All_4 TR5/TR250 Switching a TR3 wiper motor over to a TR250 Triumph 4
vping T-Series Pulling the Engine & switching to OD MG 10
D Switching seats Spridgets 5
B TR6 Switching to 5 - 30 wgt oil for a TR-6???? Triumph 39
S T-Series Switching to electronic ignition...Preferences? MG 11
1 TR2/3/3A British Racing Green Paint Codes Triumph 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
KVH General TR Green Turn Signal Dash Indicator Triumph 8
C Alternative to Moss's BMC Green Engine Paint Austin Healey 10
R TR2/3/3A OEM Paint color Number for 54 TR-2 british Racing Green Triumph 5
Lin Spruce Green Healey 100 Austin Healey 17
JPSmit Green Mini - with halo headlights Spotted 0
T Dockers Light Green Metallic Paint Spec Austin Healey 2
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
PC green Swede Spotted 0
M TR2/3/3A Where can I get British Racing Green, 1958 Triumph tr3a touch up paint in the USA? Triumph 3
S TR2/3/3A green fiberglass fix it stuff Triumph 9
5 Green Bugeye on E-Bay Spridgets 22
David Townsend Florida Green Over Pacific Green BN4 Austin Healey 17
Flash_Harry General MG MGs on the Green 2014 MG 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT Other British Cars 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT TVR 0
B Off Topic British Wheels on the Green, Saturday Sept. 27th. Madison, CT Triumph 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT Sunbeam (Rootes) 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT Spridgets 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT Rover / Land Rover 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT British Motor Corp 0
B General MG British Wheels on the Green, Saturday Sept. 27th. Madison, CT MG 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT Lotus 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT Jaguar 0
B British Wheels on the Green, Saturday Sept. 27th. Madison, CT Austin Healey 0
S Green/white BN7 Chequered Flag Austin Healey 7
K TR4/4A Green and Red Warning Light Removal from Dash? Triumph 5
RJS TR4/4A 1975 Triumph British Racing Green Paint Code Triumph 4
AHS 1957 Triumph light green paint? Triumph 6
W MGA Nice looking Green MGA In Pittsboro , NC MG 1
Shinsen774 MGB Classics on the Green - 50 MGBs!!! MG 3
T It's not easy being Green Triumph 7
W TR6 Green power wire-'74 TR6 Triumph 3
B Olive green...mm..Just like sweet peas ma!! MG 13
W hd 8 red green spring placement Austin Healey 1
S Green carpet set for a 68? MG 4
