Dash wiring Plus 2 S
TomMull
I'm om the third dash wiring harness that does not fit my 1970 Plus 2 S 50/0023N Federal. This one is the closest of the three to the original but the colors do not match the old harness nor the closest diagram I can find, which is marked Plus 2 Federal 1968 - 1969. Mine was built in early 1970. There is also some slight variation in the branches, which I could live with if that was the only issue. While the old harness colors have badly faded, particularly the striped ones, quite a few of the solid colors are still distinct and I can't imagine why the new one would be so completely different. I can also find no compliance with any British wiring convention.
I started this a year ago and with Covid limitations in the UK there was had about a 3 month delivery time for each harness so my project has certainly gotten old.
In short, I have abandoned the hope of getting a replacement harness and am awaiting the arrival of bare cable from Autosparks in the colors correct according to the diagram that I have and to build a new harness.
I am hoping to match the new wires with the old wires, that are mostly tagged, with the correct color code on the diagram and the correct pins on the multi connectors to the engine (main) harness. This will be a tedious process at best.
This seems straight forward enough but an awful lot of room for errors and will be a very slow process. I'm also open to suggestions as to the idiot lights which seem to be permanently connected to the harness. Does anyone have experience with those? Of course I could always put a connector in the wire but I'm trying to keep the crowded mess behind the dash as clean as possible.
I'm no wiring expert so would appreciate any comments, suggestions, similar experiences, notes, diagrams or perhaps just wish me luck.
Thanks in advance,
Tom
Grantura_MKI
What color are you after?
TomMull
TomMull
Here is the list from my diagram. I have a few meters of each on the way from Autosparks in the UK. Price was reasonable but the shipping cost much more than the wire. You have quite the inventory and will keep you in mind if I run short.
Grantura_MKI
Let me know. I make my own harnesses for most cars that I do, and like to use the original colour codes.
I bring it back from the UK when I am over. I have quite the pile since COVID has stopped travel.
Platinum
I've found that making a harness "from scratch" makes for a neater job, adherence to the conventional British color codes and wiring diagrams makes it easier to troubleshoot later. It also does the next person to service it a favor. Like D, we kept spools of the "usual" wire in the shop to be faithful to the originals. We'd done some Italian and German cars as well, had the wire spools on separate rods. Can't tell how many rolls of 3M electrical tape, too. Never bothered to make "loom boards" a la Wrists, too many variations.
And I do wish you luck, Tom. I've got factory manual diagrams, but I suspect you do as well. If not I can scan 'em.
Grantura_MKI
No boards for me either. I run wires and wrap in cheap masking tape and add as needed. Don’t fit the ends until it is back from being cloth wrapped.
TomMull
TomMull
Thanks Dr. Entropy for the encouraging words. I do have the diagrams that came with my manual but there seems to be a gap between the 1969 plus 2s and the plus 2 S 130 wiring diagrams. They also differs with dynamo and alternator models that seem to have changed at about the same time. Just more to add to my confusion. My car has a re-manufactured Bosch alternator now, no idea what it had originally.
Thanks D. also. The wrapping raises another question. The old loom is in black tape the new in grey both very tight and stiff making the physical fitting difficult. Any suggestions for tape for my new one?
Platinum
Our +2 is a 1969, we eliminated the hood 'bubble', I'd built an engine with a Weber head. Chassis is 50/14**. The manual's diagrams for it seem spot-on. Sorry to hear yours has discrepancies.
We've used 3M's "Super 33+" tape for decades. Another time consumer is that we soldered the bullet and spade connectors, out of necessity. The crimp-on ones didn't come along until the late '70's IIRC. Still would solder in lieu of crimping tho. The dissimilarity of materials (copper/aluminum/steel) just bothers me... yet to see a soldered connection fail due to galvanic reactions, not so with a mechanical-only crimp.
Not certain when the cloth wraps were replaced with tape, early '60's, IIRC. And not all manufacturers at the same time. For one, Rolls seemed to use cloth 'til a while later. David would know better when the transition occurred.
TomMull
TomMull
Our cars seem to be very close, late 69 and early 70 but the closest wiring diagram I have specifically excludes the 70 model. I have no idea if my wiring is original either but little reason to assume it isn't.
The PO added the Weber head on mine but just plugged the holes on the exhaust manifold that crossed over to the intake. I hear you need to take the body off to do the headers. That is on the agenda.
I had planned to solder the bullets but have had good luck with the crimped spades. I have used the heatshrink Ancor crimp terminals on boats with absolutely no issues. Price is shocking but I have quite a few left over.
Tom
Platinum
Not sure if I would trust that diagram. Indicator colour code is not correct for starters.
Whole thing is bogus. A generalized, generic representation.
TomMull
TomMull
No worries D, you've helped me out in the past and trying to be helpful is what its all about. I suffer from foot in mouth quite regularly myself.
Thanks,
Tom
Platinum
Was attempting to be nice and it bit me....
Didn't bite you, D. That Akbaradeli character has posted troll BS in several forum sub-directories. It bit him.
Platinum
Just found this "pictogram" of the Plus 2 wiring, not at all certain where I got it nor its accuracy. But at least it's a bit more info.
With a grain of salt.
TomMull
TomMull
That one has come up in my research. I didn't go too far with it as it is for a Plus 2 S 130. The dash wiring on the 130 is quite different from the earlier Plus 2 S like mine. Probably lots in common too but I'm going by the Federal Plus 2 S diagram from my manual that does not match my car but will when (If?) I finish. . On hold too as I'm getting the TR3 and the Herald in shape foe a few club drives.
Finally out on the road with the group!
Tom
FlyingCat Spitfire Wiring Dash Triumph 2
JimTR4 TR4/4A dash gauge light wiring Triumph 3
charleyf TR6 Wiring harness/ dash bulbs Triumph 2
Kleykamp dash wiring Triumph 3
TulsaFred Dash wiring and grounds Spridgets 17
G O/D and dash wiring Triumph 8
V TR2/3/3A TR3a Dash Wiring Triumph 6
R Under dash wiring problem-BJ7 Austin Healey 10
K Under Dash Wiring Triumph 4
C Wedge 1980 TR8 dash wiring question Triumph 11
milemarker60 Pics of my Wiring [Masters] and Dash [Prestige] Triumph 10
S TR2/3/3A Wiring for Dash Lights - TR3 Triumph 6
P Dash wiring question Austin Healey 5
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
