O/D and dash wiring
G
Got no switch, just three wires coming up from the tunnel. Who goes to what? Rest of the dash wires are unplugged and nothing on the dash work save the temp gauge. Where can I get a good diagram and/or manual? Thanks.
'76 6
Andrew Mace
Here's a very good wiring diagram from Advance Auto Wire; OD stuff is down towards the lower right.
Notwithstanding any other wiring issues in or near your dash, the OD could be a column switch...or a slide switch on the gear knob, depending on the origin and installation of the OD gearbox.
swift6
The Bentley Manuals have a really good diagram showing dash guage and wiring layout from the service position.
TR3driver
Great Pumpkin - R.I.P
Probably two of those three wires are for the reverse lights. If you can't read the colors (or the wires have been replaced), some quick detective work with an ohmmeter (or the ohms function of a DMM) should identify them:
With the transmission in neutral, measure the resistance of each wire to ground. All 3 should show open. Now shift into 4th gear and measure each wire again. The wire that was open before and now shows somewhere around 10-15 ohms goes to the overdrive switch.
G
Original wires and the colors are hard to see. I ran it on the lift in 4th and just jumped it out directly to the noid just to see if it was working. I got it to go in once or twice. really weak spark when connecting. I think the ground may need some help as it feels loose and is covered in oil.
Thanks guys!
I'll have lots more wiring questions in the future. The dash wiring is a mess.
TR3driver
Quite possible, I had that problem with one of the Stags. Only a little bit loose, wouldn't pull off easily; but that little bit of play was enough to make the OD not work sometimes. Pulled the terminal off, crushed it just a bit with a pair of pliers and put it back.
hondo402000
you might need to take those switches apart and clean the insides. My reverse lights didnt work when I got my TR6 and turned out that the switch was stuck in the ON position or Closed as the electrical guys would say
Hondo
tdskip
There is an eBay seller that has great large format wiring diagrams that are laminated for cheap. Highly recommended!
DNK
Tom, just have him copy Dan's to a thumb drive ,take it to kinkos and have them blow it up to 36X25 if he wants
TomMull Dash wiring Plus 2 S Lotus 16
FlyingCat Spitfire Wiring Dash Triumph 2
JimTR4 TR4/4A dash gauge light wiring Triumph 3
charleyf TR6 Wiring harness/ dash bulbs Triumph 2
Kleykamp dash wiring Triumph 3
TulsaFred Dash wiring and grounds Spridgets 17
V TR2/3/3A TR3a Dash Wiring Triumph 6
R Under dash wiring problem-BJ7 Austin Healey 10
K Under Dash Wiring Triumph 4
C Wedge 1980 TR8 dash wiring question Triumph 11
milemarker60 Pics of my Wiring [Masters] and Dash [Prestige] Triumph 10
S TR2/3/3A Wiring for Dash Lights - TR3 Triumph 6
P Dash wiring question Austin Healey 5
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
I TR6 Dash light issues Triumph 19
J Attaching BT7 Dash Facia Panel Austin Healey 2
EWD TR6 Dash Pad Replacement Triumph 3
longbridgehealey Bugeye dash Spridgets 6
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
Basil New Dash Cover in the Telly Other Cars 3
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
steveg TR6 Metal Dash - does anyone make one? Triumph 13
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Dash repair Triumph 7
M Getting behind the dash on BJ8 Austin Healey 4
Rut TR4/4A Dash color Triumph 9
Rut TR4/4A TR4 wood dash Triumph 26
J Walnut veneer for the dash, Look what I found! Austin Healey 12
