Kleykamp
'61 TR3. I will be replacing a headlight switch, because one terminal is broken off the existing switch. The broken terminal is missing. One terminal is blue/brown,one is blue and the third is ??? as I have no visible wire that is not accounted for, except a red wire with half of a fuse holder attached, which appears to go to the dash light switch which is a rheostat. I dont recall my two previous '59 TR3's having that type of switch and Haynes manual schematic shows more than one red wire out of that terminal to tail/park lights. Does the red wire with fuse link go to the light switch terminal and clip into the space at the bottom of the dash? If so, what amp fuse? I guess I need one of those handy color wiring diagrams,but until I can get one,maybe someone remembers how this goes. Also there are several(maybe 5) red or red and white wires attached to the rheostat. Is this correct or something that was rigged through? Sorry to be so wordy. Thanks,Joe
