TR2/3/3A Wooden piece under scuttle with dash
jfcdo
As I continue with the restoration of my 1955 TR 2, I find that there is a wooden piece under the scuttle where the dash mounts.
This piece follows the curve of the scuttle from side to side.
This piece is not in good shape and it would be quite a task to reproduce this piece.
Is there a good workaround for this or are these pieces available any where?
As always, any advice that anyone can offer is appreciated.
Thanks, JC
J
jfcdo
Yes! Thank you. This is just what mine looks like.
Thanks for the link/post/photos/instructions.
Looks like I'm gonna be a carpenter for a while.
Thanks again, JC
DavidApp
Hello JC
Post photos of your progress so we can see how you are getting on. You may get advice from the carpenters on the forum.
I did enjoy following John as he worked through that section of his rebuild.
David
CJD
Hope it helps. I have been thinking about any other "work arounds" like you asked. I suppose you could use a composite (read plastic) material so you could fashion the initial block in a single piece. But either way you will have to spend a while with a sander to shape the ends. I also reviewed the build, since it's been about 5 years since I did mine. I see I also used a table saw and router...as additions to the tool list. You could live without a router by using the table saw and a daddo blade, but I think the table saw would be hard to do without.
After doing so much metal and greasy mechanical work on a restoration, I remember I enjoyed taking a break to do a week of woodwork. It's a nice diversion.
J
jfcdo
Thanks again for the support.
It seems that I will not need to fabricate this piece of wood.
The piece of wood came from under the scuttle of the original body.
As that original body was in pretty bad shape, I had to replace many of the pieces, including the scuttle.
I see now that the new scuttle does not need this piece of wood.
I had already begun to fabricate a new piece, or I should say I had someone begin to fabricate one.
As I was not confident that I would be able to do this myself, I brought a good piece of wood, hickory as I recall and the old piece to a local high school wood shop teacher and asked if he, with his students could reproduce this piece.
This project made for a great teaching/learning experience for all of them.
They got pretty close to completing this project and left the "fine tuning" of the project to me.
I remember the teacher saying that he was amazed that this piece had been part of a car and that so many of them had likely been produced, but we also observed that this was all done back in the 1950's.
Anyway, I put this story out there for those who are like me, who do not have a lot of wood working skills. I have a hard enough time with body work, although I have learned a lot from Frank Sargent's book "The Key to Metal Bumping".
Again, thanks to all who have chimed in on this thread.
JC
sp53
The tr2 shuttle is what makes the car because it does not have the pull vent. Triumph used the wood up until 1960 and the 1960 and up had a different hood with raised hinges and sheet metal to hold screws, so try the hood fit before you get to far. I am not sure and it might work out especially if you use the newer hood.
I saw John’s pictures on making a new wood frame basically all around the car and was impressed, and I am a carpenter. Anyways, the wood gets hidden, so a work around might be to just jig saw or band saw some ¾ high density plywood, and stick a couple those together for backing/ something to hold screws. Do you have an original tr2 hood?
steve
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
AUSMHLY Wooden shift knob, how to refinish Austin Healey 35
Zitch Wanted WTB - wooden Steering wheel Horn button holder [Missouri, USA] Triumph Classifieds 1
catfood Wooden seat runners Austin Healey 9
B Advice on Wooden Header and Side Trim Rails for a BJ7 Convertible Top Austin Healey 9
S TR2/3/3A beach wood- wooden handled screwdrivers Triumph 6
Rut TR4/4A Wooden dash number Triumph 2
J ??Purpose of extra holes in wooden seat runner spacers?? Austin Healey 4
P TR6 Wooden panel in trunk Triumph 2
E TR4/4A TR4 Wooden Dash Facia vents Triumph 13
A TR-3A wooden center dash panel photo??? Triumph 3
5 TR2/3/3A Wooden blocks Triumph 3
andrea Wooden Fuel Stick for 100/6 tank Austin Healey 8
R Building Wooden Steering Wheel Austin Healey 6
rlich8 Seat Rail Wooden Buffer Strips Triumph 3
I Bugeye wooden slats for seats? Spridgets 3
L Wooden Brakes MG 2
JPSmit Another Wooden Midget Spridgets 10
B small wooden gaskets for 1500 engine. Triumph 9
T TR4/4A TR4 Wooden Dash Triumph 19
pa297pass TR4/4A TR4 Wooden Dash Triumph 13
I Wooden luggage rack Triumph 3
Newkie Now, Im looking for a wooden shift knob MG 6
Newkie Looking for a wooden steering wheel for my 73' B MG 22
M free wooden shift knob Triumph 1
M For Sale Vintage Modular HTN 3 Piece Racing Wheels 13" Triumph Classifieds 0
Y MGB Time for another puzzle piece.... MG 5
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
S TR2/3/3A copied an old original interior piece and carpet pad Triumph 6
J Nut size for BJ8 center console trim piece Austin Healey 8
S TR4/4A Vinal interior trim piece eaten by rodent Triumph 3
S TR4/4A Identify piece with a picture Triumph 7
S TR4/4A Identify this piece Triumph 1
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
Rhodyspit75 Bugeye grill surround piece Spridgets 5
KVH TR4/4A Front Coil Spring Packing Piece Triumph 12
Jim_Gruber A beautiful piece of jewelry for Bugsy/ Christmas came early Spridgets 12
G TR2/3/3A Steering Column Support for One-Piece Steering Column Triumph 3
D TR4/4A unidentified, but maybe a manifold piece? Triumph 16
Jim_Gruber A Quality Piece of Kit for Bugsy IV - Creative Spridget Rear Disk Brackets Spridgets 8
B BJ7 Drain Channel and Small Waist Trim piece question Austin Healey 13
T TR6 two piece gearbox tunnel Triumph 5
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
Gliderman8 TR6 One piece drive shaft? Triumph 6
nevets Nice NYT piece about a Cobra Austin Healey 0
Marvin Gruber Front shroud piece needed Austin Healey 16
