TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...?
Popeye
Bronze
All,
As I rebuild my TR4A engine (> TR4/4A - Engine Assembly by a rookie (me!) <), one half of my front pulley is bent. (Believe this happened during disassembly, as it was reasonably straight previously.)
My intent is to keep things stock as much as practical, for example I plan on fitting the OEM generator.
The replacement steel pulley is backordered at TRF, same at other suppliers, including the UK ones.
Should I:
1. Wait for the parts to arrive? I figure I have about three months before I can start the engine (and get my carbs back from Joe Curto).
2. Replace with a one-piece alloy? BPNW and Rimmer both have single piece options. If I replace with alloy, do I go with "narrow" or "wide belt?
Rimmer part numbers
107252ALLOY - Crank pulley - Narrow Belt - Undamped > Crank Pulley - Narrow Belt - Undamped - Alloy - 107252ALLOY | Rimmer Bros <
107252X - Crank pulley - Wide Belt - Alloy > Crank Pulley - Wide Belt - Alloy - 107252X | Rimmer Bros <
110023ASSY - Crankshaft Pulley - 1 Piece - Alloy > Crankshaft Pulley - 1 Piece - Alloy - 110023ASSY | Rimmer Bros <
BPNW part numbers
107252AN - alloy pulley narrow > British Parts Northwest Alloy Crankshaft Pulley Narrow Belt Alloy TR3 to TR4A <
107252AW - alloy pulley wide > British Parts Northwest Alloy Crankshaft Pulley Wide Belt Alloy TR3 to TR4A <
What is the group consensus on pulleys?
Thanks!
Platinum
Bent pulleys introduce premature belt wear and vibration. Water pump and generator will "feel" it as well. As for the width, what are the other pulleys? Go with what belt width fits those. And if the back ordered one shows up, an easy swap.
sp53
I would go stock with the pulleys and belt. Some of beauty in these are cars is there vintage originality. I would even consider filling the pits in your hub with epoxy and then sand the hub by hand until smooth if it is not too far gone. Even the best of these cars leave their small marking on the drive way from various spots. They are not house broken. Do the best you can without spending crazy money on modifications and drive the car. Heck the stock maintenance books like those fluids checked.
steve
Stevenry
I bent half of my original style steel one replacing a cam shaft and replaced with the steel pulley. It seems maybe I was able to buy just the half I bent, but I could be wrong. But anyway, the point of this reply is that if you have had a reason to find exact top dead center before replacing the pulley, like timing the cam maybe, leave the engine at top dead center to put the pulley back on to check that the hole in the pulley is accurate. Mine was about 4 degrees off, so I filed notches in the pulley and painted them. I static timed with the corrected marks, and the car fires the second I hit the starter with a little choke and no gas, even after a couple weeks of rain, just like it’s supposed to.
Steve
sp53
I have not seen any pulleys on ebay lately, but they are out there. Marv Gruber on the forum might have one for sale and there are others in the classified section on the forum. I would also watch for a stock tropical fan on eBay or Craigslist. I guess Macey sells a new type tropical fan. The old fans do not cool well in traffic.
steve
TFB
I love looking at the cars restored to original,but wanting a driver with reliabilty I went the other route which was easy since not only was my Crank hub bad but the fan,radiator, generator and starter all needed rebuild or replacement.
So I went with the moss thin belt dampened pulley fan eliminator,a wizard elec.fan combo. alternator and hi torque starter.
8yrs and 20k of trouble free driving.
BTW it was all the great info and experts on this site that helped my decisions.
Have fun
Tom
Popeye
Popeye
Bronze
steve
First off, thank you all for your input and replies.
I had a conversation yesterday evening with Scott Harper at Team Triumph. He has the OEM steel pulley, and it is on its way to me. Yay!
I had also reached out to Marv yesterday (and later let him know I had found the part). Steve, thank you for the suggestion.
For the record, the kind folks at Rimmer tell me parts 107252X and 110023ASSY are identical (albeit differently priced). They are an alloy pulley manufactured by Bastuck.
Popeye
Popeye
Bronze
Have fun
Tom
I may yet change to better cooling... I'm starting with stock, but still need to decide on my radiator: (1) re-core, (2) replace with OEM, or (3) replace with aluminum. Unfortunately I had the original radiator cleaned and pressure tested by a radiator shop - and then poked a hole in it when removing a garage door. Argh!!
TFB
The only problem with my wizard setup was the fan relay failed a few weeks ago..I could have popped in any 5pin relay but wanted the oriiginal replacement so I drove for a week with no fan.80 and 90 temps no problem ,just had to avoid stop and go traffic.
I dont get when lots of time and money is spent to rebuild motor and than connect to a 60yr old radiator because it doesnt leak.At least you had leaked checked.but cleaned can mean different things.If it was dissasembled,rodded out to shiny inside tubes that is way different than trowing in clean tank for awhile.
If you go option 1,2(new oem) or 3,poking that hole may have been actually good luck.
Tom
Platinum
I understand the desire for originality, but down here the humidity percentage level usually matches the temperature numbers. I converted the MGB to an aluminum radiator and put a "pusher" electric fan on it, using a relay. have both a thermocouple switch on the rad and an over-ride switch in the car. Now July in traffic is not a problem. Best bit of "modernization" on the car.
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Crankshaft pulley / damper Austin Healey 5
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
vette Timing Cover crankshaft pulley seal Austin Healey 6
Tugboat Crankshaft Pulley Question Triumph 4
regularman Crankshaft pulley nut for 1500 engine Triumph 5
kyreb1862 80 B Crankshaft Pulley MG 6
R Crankshaft pulley bolt MG 8
Colin8 1098/1275 Crankshaft Pulley - Damper Spridgets 3
abarth69 Crankshaft pulley bolt Spridgets 1
tony barnhill 1275 Crankshaft Pulley Spridgets 2
BritSpit Removing Crankshaft Pulley Nut Triumph 22
R 1500 midget crankshaft pulley nut removal? Spridgets 2
Brosky TR6 Diameter of crankshaft pulley on TR6 Triumph 17
B Spare crankshaft pulley for BN1? Austin Healey 0
G loose pulley on crankshaft Triumph 3
mctriumph TR4/4A Busted crankshaft Triumph 20
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
