Replacing the crankshaft damper [harmonic balancer]
pschauss
I need to replace the crankshaft balancer. Can this be done with the engine in the car or do I need to at least lift it a bit off of the motor mounts?
What is the best kind of puller to use for this job?
Thanks,
Peter Schauss
1963 BJ7
Keoke
I need to replace the crankshaft balancer. OK!
Can this be done with the engine in the car?----? YES
do I need to at least lift it a bit off of the motor mounts? ------> YES
What is the best kind of puller to use for this job?----> Shortest Three legged one you have that will grab it.
AS BOB Noted:
Your biggest problem will be getting the large nut off the balancer/pulley. .----> Here My Impact wrench worked a treat.
I did this a couple years ago. Yes, you have to unbolt the motor mounts (easiest at the chassis). You also have to disconnect the throttle shaft on the engine and the tie rod on the OD. I lifted the engine with a floor jack and a 2x4 under the pan, which left a nice impression of the 2x4 on the pan (didn't cause any problems, though).
Your biggest problem will be getting the large nut off the balancer/pulley. You have to 'lock up' the engine and use a) a large breaker bar and socket b) the starter or c) a 3/4" impact wrench which doesn't really fit between the balancer and the front chassis cross-connect. (a) and (b) didn't work for me, but (c) did with some finagling. If your water pump has 50K or more miles on it you should consider replacing it while you're at it, but I dunno a reliable source for a new one (Michael Salter does good rebuilds). Check your timing cover seal--you'll want a new one with a new/rebuilt balancer--and timing chain tensioner while you're at it.
Why are you replacing the balancer? They can be rebuilt.
bdcvg
I actually bought the correct size wrench for this, the box end fits good and clears the little bit of cross member left in the way. I'll have to check the size tomorrow.
1-11/16"
steveg
With a BJ7, you should be able to unbolt the balancer from the pulley without removing the pulley -- if you don't want to do the other stuff as is recommended above.
I did this last time and sent my damper out to Damper Dudes to be rebuilt - quite reasonable.
I used this setup to lock the crank:
P
pschauss
Ok. I have the engine raised enough to get the socket on the nut but the impact wrench does not budge the crankshaft nut. It is a right hand thread isn't it?
Thanks
Keoke
Thanks
I think SO been a while,but Impact wrench I used had a torque of 300 pounds or so!-??
dcarlg
Yes, righty tighty. I just reinstalled mine after a Damper Dudes rebuild.
HF electric impact wrench worked for me. Borrowed gear puller from Advance Auto.
Good luck.
Douglas
P
pschauss
Thanks for all of the advice. One of the engineers I work with suggested that I might need more airflow to my impact wrench. He suggested that I increase the pressure at the tank by 10 psi to compensate for the fact that I was using a 3/8" hose instead of 1/2". I had to let the impact wrench hammer on the nut for a few minutes but it finally broke it loose.
Since my gear puller removed damper and the pulley together I am going to replace the front seal while I have access to it. Can this be done without removing the timing chain cover?
Peter
1963 BJ7
RestoreThemAll
Why not at least inspect the timing chain/gear/guide/tensioner? You're almost there. Also, you might take a close look at the crank shaft snout. Mine needed a little cleaning up. It was a little rough around the seal area. Not concerning but I bet it would have leaked if it were left that way. That's easier done with the timing chain cover off.
P
pschauss
Thanks for all of the suggestions so far. I pulled the timing chain cover and everything in there looked to be in good shape. (The engine has about 30k miles on it since it was rebuilt 19 years ago.)
I successfully installed the combined damper and pulley that I got from Moss Motors.
Next question: The new damper has a deep recess where for the crankshaft nut. What is the best way to access the locking washer to bend it up to lock the nut?
Thanks,
Peter Schauss
1963 BJ7
Thanks,
Peter Schauss
1963 BJ7
That would fall into the by any means necessary category! I think I would try levering it up with an appropriate-sized screwdriver, keeping the flat-blade parallel to a flat on the nut. If required, you could finish it off with a pair of Channellocks.
P
pschauss
After more than six weeks of working on the car off and on, I have the car back on the road. As I mentioned in a previous post, the new lock washer barely fit into the recess in the new damper so that there was no way to get any tool on it to bend it up against the nut. I talked to the tech rep from Pro-Race and the Moss technical people and both agreed that if I using blue Loctite and torqueing the nut to 90 ft-lb would be sufficient. I will be checking it regularly.
If I had to do this again I would replace the bolts which hold the motor mounts to the chassis with longer bolts before lifting the engine. When reassembling the car, I spent a number of hours trying to get the holes to line up. Ultimately, I had to remove the carburetors and the heat shield so that I could get the mount on the driver's side bolted down.
Patrick67BJ8
I used studs and that allowed me to easily line up the motor mounts with the frame holes. Very easy to do with studs!
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
J TR4/4A Replacing springs Triumph 7
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
R TR2/3/3A Replacing rear springs Triumph 51
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
T Replacing the crank pulley/damper Austin Healey 4
M TR4/4A Replacing the hood/bonnet onto the body Triumph 11
T TR4/4A Replacing Drive Train Seals Triumph 5
