refresh my foggy memory - replacing clutch in my 67 Midget
Jer
The release bearing is shot on my 67 Midget & I will replace the clutch with a borg & beck & make sure the release bearing isn't one of those "pinned" ones that are prone to breaking off, the last borg & beck I used seemed good.
My question, I was hoping to avoid pulling the gearbox with motor & just separate & pull the motor, I hate installing the driveshaft etc. Is there any issues with pulling just the motor ? Only other time I have done this was to rebuild the gearbox in my 74, so everything was pulled as a unit, just thought I would check before getting into the project..
Thanks
David_Doan
On my 59, I pulled the motor only the 1st time. I don’t remember any significant challenges. I also took out the 4 tranny mount bolts (since the tranny was coming out too), but I don’t think that’s required.
The hardest part will probably be putting the motor back in and mating it to the tranny while in the car.
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
K TR2/3/3A Turn signal and control head memory refresh..... Triumph 9
T TR2/3/3A Questions on TR3A steering control head refresh Triumph 34
M Undercarriage Refresh Austin Healey 25
Zitch TR4/4A Early 63 TR4 [CT16438L] Dash refresh Triumph 3
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
WillR MGB What happened to a simple engine refresh? MG 12
RickB Vinyl top refresh / renew? Spridgets 10
Morris Refresh my memory... Spridgets 5
K Memory Refresh:What oil to use after break-in? Triumph 1
K SU Mix Adjust Memory Refresh Triumph 7
jhorton3 Rear Suspension Refresh Spridgets 28
tosoutherncars 1500 top end refresh Spridgets 4
10musketeer Clutch Peddle Box- Refresh my memory Spridgets 7
T A Type Overdrive "Refresh" Triumph 11
J Gas tank refresh Triumph 5
AH67 Polishing Foggy side curtains on BT7 Austin Healey 13
M Foggy windows MG 8
Hedgehog Plastic conv window foggy Restoration & Tools 3
G Foggy guage glass Triumph 6
kodanja Foggy Gauges? Triumph 14
Bayless Memory block Spridgets 3
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
Rut Help a bad memory out... Spridgets 6
GTP1960 Drive down memory road. Other Cars 14
NutmegCT Memory test Other Cars 9
F Sharing Memory Lane in an Austin Healey Austin Healey 7
PAUL161 Happy/Sad Memory, My Old Austin Other British Cars 2
Nelson Senior memory aid Spridgets 12
B A sad memory of a fellow Midget Owner. Spridgets 5
jlaird Someone jog my old memory Spridgets 20
Cain Stereo Memory Wire/Speakers Triumph 4
