    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Foggy windows
MGBGirl
Member
My front windscreen keeps getting cloudy. Also, the windows on my soft top are pretty coudy too. Any kind of special spray to keep it from fogging up and to clear them up? Its a pain to look through when im driving. Thanks.
There is a couple of products out there . Novus is one I like from the windshield people
I've heard that Novus is a good product for plastic windows also but your front windscreen getting cloudy makes me wonder if your defroster isn't performing well.Mabey the cables that move the floor/defog flap need some attention..IE its not directing the air properly to the top of the dash?
The cables are fairly easy to get at ,should be right above your right knee area behind the dash as you sit in the car, look for the part that holds the cable outer sheath and make sure the inner and outer parts of the cables aren't moving at the same time when you move the heater controls back and fourth.
How does the blower fan perform? Here is a good link I found about the way the MGB heater/defroster system works.
https://www.mgb-stuff.org.uk/heatertext.htm
Good luck,hope this helps a bit. Mark
Sorry, about the front window, it's not that the defroster doesn't work, we have not actually had to try it out yet. It just gets cloudy from sitting in the driveway. It's not moisture on the window. But thanks for the website because I don't think my vents are working and that might help.
MGBGirl said:
Sorry, about the front window, it's not that the defroster doesn't work, we have not actually had to try it out yet. It just gets cloudy from sitting in the driveway. ...
Don't park under a tree?
I don't normally park under a tree. I only do when we are working on it in the back yard but it's cloudy even if it's not under a tree.
Is your heater connected?
Core leaking will cause windshield to fog up like that...as will wet carpets.
The tree was an attempt at humor ,sorely missed its mark
AH67 Polishing Foggy side curtains on BT7 Austin Healey 13
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
Hedgehog Plastic conv window foggy Restoration & Tools 3
G Foggy guage glass Triumph 6
kodanja Foggy Gauges? Triumph 14
waltesefalcon Miata windows Other Cars 4
kodpkd Side Curtain Windows Austin Healey 11
B Wanted wing windows gt6 Austin Healey Classifieds 0
C Wanted 100/4 BN2 1956 Le Mans side windows Austin Healey Classifieds 0
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
S For Sale FOR SALE BN1 100-4 Healey Perspex Side Screen windows [California, USA] Austin Healey Classifieds 2
T Post-War Other The Herald front vent windows Triumph 5
vette BJ7 Side Windows Austin Healey 21
7 How to replace door windows on a 77 MG Midget Spridgets 6
B New Window Seal for BJ7/BJ8 Roll Up Windows Austin Healey 1
J Power windows for BJ8 Austin Healey 22
W Looking for tips: BJ8 roll up windows Austin Healey 10
TR6oldtimer TR6 TR6 soft top frame not aligning with windows Triumph 1
S Bags for side windows Austin Healey 11
H TR4/4A 4A door windows Triumph 6
AUSMHLY How to get a good seal around side windows BJ8 Austin Healey 6
Jim_Gruber Swapping Vent Windows from a '72 into a '68 Spridgets 10
W Removing windows in 74 Jaguar XJ6 Jaguar 1
af3683 Cleaning Convertible Top Plastic Windows Triumph 4
PAUL161 Cleaning soft top windows. MG 0
livinginthepast De-yellowing old convertible windows Spridgets 3
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
D side windows bn2 Austin Healey 1
M Dynaplastic hardtop with portal windows ? MG 3
L need mini windows British Motor Corp 5
RickB Cleaning of plastic windows - just tried McGuire's Spridgets 5
angelfj1 How to restore Perspex lites [windows] Triumph 7
A 1950 Ford Prefect Windows Other British Cars 4
Gerdo How to keep your plastic windows clear? Restoration & Tools 32
J BJ8 windows Austin Healey 4
D plastic windows Austin Healey 0
P MGB WINDSHIELD TO BODY SEAL & VENT WINDOWS '79 MGB MG 3
G convertible top windows fogged MG 4
H scratches in windows Restoration & Tools 4
P Windows on Convertible top Restoration & Tools 2
G Side curtain windows for Bugeye Spridgets 1
