TR4/4A Early 63 TR4 [CT16438L] Dash refresh
Zitch
So I decided the ol' TR4 needs some attention.
I'm starting with the Dash, floors and other stuff to come.
This is what the dash looked like when I picked her up a couple years ago.
FYI the steering wheel and horn button have been replaced. (still have the Les Leston)
Not bad but not what I want it to look like.
Pictures I took of the metal Dash board removal
**** choke ...
Has anyone Used the RevingtonTR early switch Plith? I think I may need a new switch plith.
Got my old Plint apart. I show how the washer squirter has a screw on knob(I broke), and the Choke pull has a nut from behind with a push on knob.
disconnect ..... disconnect ..... disconnect .....
Remove Steering......
Remove Gauges ...
Manual Washer pump .... who knew!
And OUT!
mix of rattle can wrinkle and original spa white!
I decided to have the metal dash powder coated Cardinal Pure White. Closest I could get to what was on the back of the dash(spa white).
And we wait for the powder coater.....
I have the Crash pads need to start prepping those.
Any other While I'm there that people recommend?
I think I'll do the Choke cable and update the grommets, dash bulbs, and update the squirter hoses.
ghawk16
Haven't used the Revington TR plinth...but mine is all cracked and bent so I may look into it! Look forward to seeing the pics.
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
T TR4/4A TR4 early dash Triumph 7
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
J TR4/4A TR4A radiator install into a early TR4 ??? Triumph 14
Marvin Gruber TR4/4A Early TR4 gauge glass Triumph 13
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
HerronScott TR4/4A Early TR4 gauges on Phoenix Craigslist Triumph 2
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
T TR4/4A Early TR4 Steering Triumph 2
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
T TR4/4A Early TR4 Hood Stick Covers Triumph 14
SCguy TR4/4A Early TR4 Seat Tracks Triumph 2
T TR4/4A Early TR4 Clutch Triumph 7
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
milemarker60 TR4/4A Need some early TR4 Windshield Frame Pics -Please Triumph 0
T TR4/4A Early TR4 - Windshield Trim Covering Triumph 10
T TR4/4A Early TR4 Choke Cable Routing Triumph 6
SCguy TR4/4A EARLY TR4 SWITCH PLINTH Triumph 3
T TR4/4A Early TR4 - Timing Cover Oil Seal Triumph 3
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
T TR4/4A Early TR4 - Crank Pulley Woodruff Key Triumph 7
T TR4/4A Early TR4 - Front Brakes Triumph 3
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
