TR4/4A Early TR4 - Front Brake Calipers
T
TRDejaVu
I am trying to fit new pistons into new seals.
The manual says to:
- fit the seal into the bore - done.
- fit the dust cover lower edge into the caliper groove - aargh (not done).
- slide the piston through the dust cover and past the bore seal into the caliper - tried this first and it won't get past the seal even with liberal amounts of new fluid.
What is the trick in getting the dust cover in place and then managing to keep it there while I try and fight the piston past the seal without damaging it?
Alan_Myers
Hi Ian,
First, go to a local auto parts store and get some Raybestoes "Brake Assembly Oil"... This stuff is much better to work with than brake fluid! And, it's compatible with all types of brake fluids.
Next, yes it's tricky initially to get those dust seals in place. You can search the archives here for more details, I know it's been discussed, but in a nutshell:
Close the bleeder screw and block off the opposing piston hole, then use *gentle* compressed air blown into the pipe connection to pop or "baloon" the rubber seal outward around the face of the piston. Note that only a gentle amount of air is needed, not a full blast.
A dull-pointed tool made from copper wire or a wooden popsickle stick or some sort of hard plastic can be very helpful getting the seal around the piston, too. You do need to be careful not to damage the seal, as you noted. That's why I suggest a relatively dull homemade tool.
After one side is done, lightly clamp it so that compressed air won't pop it back out, while working on the opposite side.
What I use to block the open piston hole are a couple plates of 1/8"x3" steel that are cut to the right length to extend a little beyond the caliper and allow me to use some C-clamps on them, with a piece of sheet rubber under the steel at the piston hole to form a reasonably good (if temporary) seal.
Note: You are well beyond this point, but the same plate steel and C-clamps are handy during disassembly, too. These will keep one piston in place while starting the other out with compressed air. No rubber seal is needed in this case. I pop one piston partways out, while the other is clamped. Then reverse the process and clamp the partially removed piston while using air to dislodge the second piston.
Hope this helps!
Geo Hahn
[ QUOTE ]
What I use to block the open piston hole are a couple plates of 1/8"x3" steel...
[/ QUOTE ]
But if you don't have a suitable piece of steel handy you can insert the opposite piston w/o it's boot to block the other side.
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
T TR4/4A Early TR4 - Front Brakes Triumph 3
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
Zitch TR4/4A Early 63 TR4 [CT16438L] Dash refresh Triumph 3
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
T TR4/4A TR4 early dash Triumph 7
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
J TR4/4A TR4A radiator install into a early TR4 ??? Triumph 14
Marvin Gruber TR4/4A Early TR4 gauge glass Triumph 13
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
HerronScott TR4/4A Early TR4 gauges on Phoenix Craigslist Triumph 2
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
T TR4/4A Early TR4 Steering Triumph 2
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
T TR4/4A Early TR4 Hood Stick Covers Triumph 14
SCguy TR4/4A Early TR4 Seat Tracks Triumph 2
T TR4/4A Early TR4 Clutch Triumph 7
milemarker60 TR4/4A Need some early TR4 Windshield Frame Pics -Please Triumph 0
T TR4/4A Early TR4 - Windshield Trim Covering Triumph 10
T TR4/4A Early TR4 Choke Cable Routing Triumph 6
SCguy TR4/4A EARLY TR4 SWITCH PLINTH Triumph 3
T TR4/4A Early TR4 - Timing Cover Oil Seal Triumph 3
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Crank Pulley Woodruff Key Triumph 7
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
