TR4/4A Early TR4 gauge glass
Just got an early TR4. All the glass in the gauges are round like TR3 gauges,I thought all TR4s had flat glass. Think someone changed these out or is this correct for early TR4's?
Marv
Mickey Richaud
I read somewhere that the early ones did indeed use up the leftover stock of gauges before going to the flat ones. Maybe in Piggott's book...
TR4nut
For sure, early ones had dome glass - also the center gauge setup was checkered aluminum, not painted. The temp gauge on what you have is occassionally coveted by the TR3 crowd because it looks so similar yet is electric so a decent replacement for the capillary type.
bgbassplyr
:iagree:
My CT5589 has the dome glass but the painted center gauge insert.
T
TRDejaVu
My recently departed TR4 CT 89xx had domed glass. I even fitted it into the voltmeter I used instead of the ammeter.
HerronScott
Marv,
What everyone else above said. Early TR4's up to the commission numbers below had gauges similar to the TR3 with domed glass and the fully exposed needles.
TR4 RHD to CT15053, TR4 LHD to CT11307
Some pictures here of early and later TR4 gauges and center section.
Piggot's The Restorer Guide
What's your commission number?
Scott
BRSLimited
I've seen a couple of cars that had both, flat speedo and tach and domed center guages. Don't know if they were changed out at some point or if they ran out of the larger glass before the smaller.
Marvin Gruber
This one is titled as a 63, commission number is CT8385 L. I asked the PO, he owned it for 15 years. Said the gauges were original as far as he knew. He installed a (nice) wood dash in the car. I might change it back. I have one of the early aluminum gauge centers. Would this car have it or the black center.
Marv
HerronScott
Marv,
In the link to Piggot's book, he states that after CT4398 it was black crinkle finish.
Scott
Marvin Gruber
Scott,
Meant to tell you, this TR4 came from Norfolk, VA. Off the Military base. An Officer going to the Joint Chief Staff College. Car had lots of upgrade stuff on it. He had it 15 years before he gave up.
Marv
HerronScott
Marv,
How do you find these? (Not that I'm in the market for any more projects!) :smile:
Scott
Mickey Richaud
THEY find HIM!!!
BRSLimited
They seem to find me too, first the TR4, now I just got a line on 3 ::gasp:: MG's that have been sitting in a barn for years. I should find more out about them in the next few days.
Marvin Gruber
Been playing with them since 1976, they do seem to find me. I looked at 3 TR4's today, rough but lots of good parts. Will probably get them. Somebody's gotta do it.
Marv
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
Zitch TR4/4A Early 63 TR4 [CT16438L] Dash refresh Triumph 3
Gerald_Gordon TR4/4A Failure of new door-check strap on an early 1961 TR4 Triumph 6
Willie_P TR4/4A Fan Hub Extension removal early tr4 HELP Triumph 9
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
T TR4/4A TR4 early dash Triumph 7
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
J TR4/4A TR4A radiator install into a early TR4 ??? Triumph 14
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
HerronScott TR4/4A Early TR4 gauges on Phoenix Craigslist Triumph 2
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
T TR4/4A Early TR4 Rear Suspension Triumph 22
T TR4/4A Early TR4 Steering Triumph 2
SCguy TR4/4A Early TR4 with leaky carbs Triumph 6
T TR4/4A Early TR4 Hood Stick Covers Triumph 14
SCguy TR4/4A Early TR4 Seat Tracks Triumph 2
T TR4/4A Early TR4 Clutch Triumph 7
SCguy TR4/4A Early TR4 Front Bumper Brackets? Triumph 1
T TR4/4A Early TR4 Front Bumper Overriders Triumph 4
milemarker60 TR4/4A Need some early TR4 Windshield Frame Pics -Please Triumph 0
T TR4/4A Early TR4 - Windshield Trim Covering Triumph 10
T TR4/4A Early TR4 Choke Cable Routing Triumph 6
SCguy TR4/4A EARLY TR4 SWITCH PLINTH Triumph 3
T TR4/4A Early TR4 - Timing Cover Oil Seal Triumph 3
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
T TR4/4A Early TR4 - Rear Leaf Springs Triumph 3
T TR4/4A Early TR4 - Rear Brake Cylinder Installation Triumph 5
T TR4/4A Early TR4 - Front Brake Calipers Triumph 2
T TR4/4A Early TR4 - Crank Pulley Woodruff Key Triumph 7
T TR4/4A Early TR4 - Front Brakes Triumph 3
T TR4/4A Early TR4 - Rear Brakes Triumph 1
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
