TR4/4A Replacing springs
jwolf
1964 TR4
With the lower spring pan removed and the control arms off, do you think I will be able to replace the springs without using a spring compressor, or is this simply a necessary evil??
Hamish Racing
necessary evil i am sure
but a threaded bar and some plate metal at the bottom (the same size as the bottom shock absorber bracket) and a big washer twin lock nuts at the top. is an easy diy system
please don't be tempted to use the twin system on the outside of the spring.
our cars don't suit these and will spit them off at you with some considerable force.
Ted33
I can attest to the DIY system mentioned above. It works like a charm. One useful tip is to grease the threads so the nut turns easily on the threaded rod to compress and release the spring.
Tybalt
There is an amazing amount of energy stored up when the spring is in the compressed condition. You definitely want to use a spring compressor for the task at hand. Both Roadster and Moss offer up a spring compressor. Roadster tool number is RFT102 for TR2-4 only or the RFT104 with both bottom plates so you cover TR2-6. Moss offers two, 386-895 which is similar to the Roadster tools except that it covers TR2-6 and is priced in line with Roadster's RFT104 covering TR2-6. They also offer a reproduction of the Churchhill factory tool covering TR2-6 but its cost is close to 4X the cost of the other tools.
Take a look and you can see how the Roadster and Moss tools are set up and how you may be able to make a similar tool on your own for less.
As for those twin screw with hooks type that go outside the springs that Hamish warns about, we call those "suicide sticks" for a reason.
Sarastro
Don't even think about doing that job without a spring compressor! You can make one easily from 1/2" fine threaded rod, a steel plate that fits where the lower end of the shock absorber was mounted, and a few nuts and large washers. Use plenty of lube, of course.
KVH
I agree that a spring compressor is essential--the threaded rod type. But if I can add a bit to this thread: What about the spring spacers/packing piece? With the new longer coil springs from Moss (maybe 10.25"), I believe the spacer/packing piece be avoided, dispensed with? Looks like Moss is out of stock on the springs just fyi.
R TR2/3/3A Replacing rear springs Triumph 51
D Replacing rear leaf springs ? Triumph 6
D Noise after replacing leaf springs Austin Healey 6
bighly Replacing rear leaf springs Austin Healey 10
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
S MGB 1978, replacing the clutch. MG 3
PAUL161 T-Series Replacing Transmission MG 3
S TR2/3/3A Replacing the cam shaft Triumph 27
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
L Replacing veneer on wood dashboard Restoration & Tools 14
D TR6 Replacing Horn insert in steering column Triumph 11
69MGC MGC Replacing an Outer Wheel Well panel MG 3
maxwedge5281 Replacing Factory Hardtop Rear Window Austin Healey 24
BN6_2197 Replacing gearbox switch of the overdrive system Austin Healey 10
TomMull replacing walnut veneeron the dash Lotus 17
Jer refresh my foggy memory - replacing clutch in my 67 Midget Spridgets 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Replacing O/D switch with a clock Austin Healey 4
simon1966 Replacing the witches nose in-situ. BN1 Austin Healey 14
KVH TR4/4A Replacing Front Windshield Gasket Triumph 5
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
Rut Replacing rocker assembly Spridgets 1
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
J Replacing BJ7 Dash - Detailed Photos/Schematics Austin Healey 3
M Replacing front shocks, torque setting? Spridgets 2
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
Jim_Gruber Replacing Wheel Studs Spridgets 10
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
K TR4/4A Replacing a broken 4A turn signal switch indicator? Triumph 2
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
Rhodyspit75 Replacing boot floor need bracing? Spridgets 2
RickB MGB 1980 MGB No rear brakes after replacing MC & booster MG 5
Popeye TR4/4A Steering bushing: replacing rubber with poly, do I snug to 1/8" gap or...? Triumph 3
Jim_Gruber Replacing Spridget Coolant Spridgets 21
TimK Old brake hoses need replacing, if you need proof look here... Austin Healey 1
KVH TR4/4A Replacing the Real Axle Tube Seal Triumph 17
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
GTP1960 TR2/3/3A Question on replacing brake lines & converting to Dot 5 Triumph 9
tomshobby replacing water pump Spridgets 1
D TR2/3/3A Patching, versus replacing floors? Triumph 15
