TR2/3/3A Patching, versus replacing floors?
DonP
Member
Lots of good stuff on replacing floors here. Not much on patching them it seems.
My 3B has pretty solid floors (thankfully!), ... except for some small flaking rust holes right around a couple of the driver's side seat track mounting holes. None more than an inch or two across.
I don't plan to take this to Pebble Beach any time soon, just a good looking cruisin' machine.
I could just cut out all the loose rust, treat the lighter surface rust with POR15 or Eastwood Rust Encapsulator and weld some sheet metal over the bad parts and drill new mounting holes? Or cut out 6 inch square sections and replace them with a couple of welded in patches?
Anybody else have to patch their floors instead of replacing them?
(Now I have to start looking for a set of seat mounts and tracks for it that I can clean up in my bead blasting cabinet.)
TomMull
Patching is what we would have done before the "frame off" restoration became the norm and since patching is temporary and reversible, there is absolutely no reason not to do it. Changing the floors is not a simple operation and although I know some people have done it with the body on, I don't think it is possible without literally cutting a couple of corners. For what it's worth,
Tom
Brinkerhoff
I've got a bunch of old seat tracks if you need. Patch away.
M_Pied_Lourd
I would go the patching route as well if the holes/area is limited. I always start of by saying that I'm going to just patch, but once you get into prepping the entire floor for painting, you will probably find areas that need more attention....
Cheers
Tush
Kleykamp
+1 to patching. I've been running this around in my head some as my floors could use a little attention. I'm thinking of buying the "cheap" floor pan and cut out the patches I need. Mine are mostly stress cracked areas rather than rust. The patches can be metal finished and you maintain as much of the original factory work as possible....which I like. Plus, when was the last time you went to a local car show and everyone was sitting around in lawn chairs, with the carpet pulled back, gazing at the highly polished and waxed floors?
Brinkerhoff
IMG_1342.jpgIMG_1345.jpgIMG_1346.jpgIMG_1347.jpgThe RH side marker lamp pod on an XK 120 front wing is a catch for mud and had rusted the pod and base metal badly. I dug up a new Austin Healey rear fender repair panel that I had no use for and carefully trimmed , rolled , and hammered it into the proper compound curve of the Jag. Welding small beads around the perimeter allowed the panel to grow into the Jaguar as it was welded . Final work with a hammer and dolly and I'm ready to place the new side marker lamp pod. About 10 hours but who's counting?
TomMull
Very nicely done, Brinkerhoff, and I'd call 10 hours on it rather speedy. Also reminded me that panels with a bit of shape to them are easier to weld since they distort less than flat ones. Might be easier for DonP to make the welds away from the tracks and use the tracks themselves as stabilizers.
Tom
I patch whenever I can. Just be sure to cut all rust out or you will doing it again ain a couple of years. I acid bath the spot over night then epoxy prime next day.
Marv
DonP
Member
Thanks for all the moral reinforcement guys. Patching it will be.
I've had this car since 1967, when I bought it out of Calumet Auto Wreckers and over the years I've done more than my share of "patching" on it; from "Beer Can" Tailpipe repairs in College to swapping out the entire front valance after a front end hit in a parking lot.
I'll get some appropriate gauge steel, dig out my nibblers and check underneath to be sure how far the rust holes might extend down there and start cuttin' and weldin'. I'll be using the Eastwood Rust Encapsulator to stop the light surface rust and protect the new steel, once it's all done.
(Anybody know what gauge steel the floors are?)
I will also be using all stainless bolts if I can get them for re-mounting the seat tracks.
M_Pied_Lourd
M_Pied_Lourd
Oh, I have some original floor sections in the garage..ill go an measure them and report back if no one else beats me to it :smile:. I'm going to guess about 18 gauge.
Cheers
Tush
TomMull
Most of the bodywork, floors included, were originally 18 gauge. Reproduction parts vary. The last floors I got were 18 as original. Tom
DonP
Member
Hi Don,
I used the stainless kits from Maceys on mine. It says he will sell individual hardware not just kits so if you have trouble finding something local there is an option for you..
https://www.macysgarage.com/myweb6/Parts/tr2_3_hdwe.htm
Cheers
Tush
Now that's ironic timing. I'm doing a frame on restoration/clean up, since most of my panels are in decent shape (and I'm way too lazy to do a Frame Off, just to be able to say I did it). But I'm taking them off one at a time to clean up, get rid of any Bondo I find then prep and prime.
In my mailbox today were the stainless kits I ordered from Macy's for the front valance and both front fenders as well as 20 of their cage nuts to fix any (or many) of the ones that "spin" coming off.
Don
glemon
I dont remember the proper guage for the floors, but I know the sheet metal they have at the hardware stores (at least the ones local to me) are too thick or too thin. I went to a local industrial metal shop, when I told him how much I needed the guy just gave me a scrap for free. 18 guage maybe.
These days I usually make my patch panels out of spare body panels I have.
CJD
The old articles call the body 20 gage. When I measure it comes in about midway between 18 and 20 gage. Of course repro parts could be anything!?! Most hardware stores sell 16 and 22 gage.
NutmegCT
<snip>
Sounds like my old TR. Some surface rust in the floorwells, with a couple of "pin *****" holes and one hole about 3/4" in diameter.
I sanded the surface, then sprayed with phosphoric acid.
https://i224.photobucket.com/albums/dd23/freemangarden/TeeYah50th/5811-5801-phosphoric.jpg
Washed, dried, then painted with POR15.
https://i224.photobucket.com/albums/dd23/freemangarden/TeeYah50th/5812-FirstCoat1.jpg
As the POR15 dried, I laid a square of fiberglass across it, then let dry.
https://i224.photobucket.com/albums/dd23/freemangarden/TeeYah50th/5813-Fiber1.jpg
Then painted one more coat of POR15.
https://i224.photobucket.com/albums/dd23/freemangarden/TeeYah50th/5814-SecondCoat1.jpg
(I also put POR15 on the underside, to cover the former holes.)
I was *very* happy with the result.
Tom M.
Edit: where you see "pin ***** holes" you should see "pin p r i c k holes".
S TR2/3/3A Patching the front fender Triumph 8
siberian BPost patching? Triumph 8
Lin Ford Versus Ferrari Question Austin Healey 23
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
S Ribcase versus Ribcase Spridgets 1
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
S Points versus Pertronix Spridgets 22
S Idle Speed Setting versus Generator Output Spridgets 3
DanLewis AN5 versus AN5L Spridgets 10
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
P Tachometer versus lights Austin Healey 5
F BN2 versus later seats Austin Healey 6
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
K TR2/3/3A TR3 9" versus 10" Brakes? Triumph 8
racer_x Wedge TR8 Headers: Rimmers versus Woody/TSI Triumph 34
G Texas Cooler Versus Flex Fan Austin Healey 20
steveHealey3000 Originality versus performance Austin Healey 38
bighealeysource Redline versus 20w50 for trans on BN6 Austin Healey 7
bighealeysource original versus replacement bumpers Austin Healey 4
svtmikey Metalastic versus generic Roto-flex couplings Triumph 5
N Ported versus manifold vaccum. Spridgets 31
fad64b Bonnet Steel versus Aluminum MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
D Weber versus twin SU's British Motor Corp 1
2wrench Cam degree wheel versus protractor Triumph 11
2wrench New versus core and rebuild versus running used?? Triumph 5
BritCarFan STP versus Purolator oil filters Jaguar 10
Newkie PPG versus Dupont MG 24
S Flywheel versus pilot bush Triumph 10
Michael Oritt Guages--mechanical versus electrical Racing 31
Daimlerdb18 Timing light timing versus static test lamp MG 7
fmichaels old harware versus new Spridgets 22
Steve_S Falcon SS versus Peco HDR MG 23
J BJ8 versus BT7 Shroud Austin Healey 11
M Side versus rear exhaust Austin Healey 24
G Midget versus Beetle Cabrio Spridgets 5
jaybird Mike's Midget - or Midget versus semi MG 4
tr6web Brake versus clutch fluid Triumph 14
I GY versus V3 needles in SU carbs Spridgets 1
C Pertronix versus Crane ignition kits ? MG 7
Basil New Mini versus old mini video British Motor Corp 0
B TR6 replacing U joints Triumph 4
S TR2/3/3A Pinion tail bearing replacing Triumph 12
B Replacing the Handbrake Cable Austin Healey 8
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
