Ford Versus Ferrari Question
Lin
[FONT=Helvetica Neue, Helvetica, Arial, sans-serif]For those who saw the movie "Ford versus Ferrari." On the Phil Remington quick change rotor/caliper assembly, how do they avoid having to bleed the brakes?
Just curious.
Lin
[/FONT]
Roger
Bronze
Exactly, they had quick-change pads and discs. They didn't change wishbones etc.
Lin
Lin
Roger and Randy,
Roger, Did you see the movie? Suspension components were replaced. Randy, that is what I would have thought also, but I think I remember that the caliper complete with new pads was also replaced. Might be wrong. Guess I will need to go see it again! Poor me.
Lin
Lin
Lin
I have done some more googling and reading. Looks like a quick way of moving the caliper out of the way was devised.
HealeyRick
Editor_Reid
Platinum
dklawson
IF they had wanted to make the calipers quickly removable it would have been possible with flush-face, no-drip couplers from companies like Staubli. These would have allowed connecting and disconnecting the brake lines with minimal to no ingress of air or loss of fluid. I don't know if these were available in the 1960s but I worked with their industrial equivalent since 1999.
Link to Staubli Flush-Face, No-Drip Couplers.
In the movie, though, IIRC, they replaced the whole A-arm assembly; I was shaking my head when I saw it. That might be quicker than removing rotor, caliper, etc. and maybe they pressure-bled somehow?
I think we're all curious because getting a good pedal on a Healey can be a real pain.
roscoe
Thank you for posting the link to the story. I think I can do a lot of stuff but reading this, it seems like some people have had magical lives and wizardly skils and yet would be the first to deny they were anything special. At least now I know how I'll zip my fly when my hands are too gnarled to work a zipper (and believe me that ain't too far down the road). It's one thing to use technology and alltogether something else to develop it. I'm not sure if there is even a path to being like the man described in this article anymore.
Lin
Lin
Rick,
that article really is a great tribute to Remington. I appreciate that you shared it. Wouldn’t it have been fun (and hard work) to apprentice with a fellow like that.
I don’t mean to insult anyone who owns one, but I have never been a fan of the over-muscled (just my opinion) 427 Cobras. However, that original 289 AC cobra was just a sweet looking car to my eye.
Lin
vette
Rick, haven’t read ur article yet but I’ve read about Rem before, he was very much under praised.
About the brakes. I wonder if their attitude might have been to sacrifice a little air in the system for the fast turn around in the pits. In most cases unhooking the brake line at the caliper won’t even create a drip and if the new caliper is filled to the max not much air would be ingested. Many mechanics today when changing a caliper never bleed the brakes.
... Many mechanics today when changing a caliper never bleed the brakes.
Do you know that for a fact? Any mechanic who didn't bleed the system after opening it up would be negligent, and liable in a lawsuit if there was a subsequent accident. I think when you get the $19.95/axle 'brake job' at Midas all you get is new pads or shoes, though (they may try to upsell rotors, drums, etc. and they may be required).
On another note, in the movie Miles found the brakes overheated on a test run, hence the 'quick change' procedure Remington developed. The movie shows the brake pedal going to the floor suddenly, I can't imagine worn pads would cause that, but boiling fluid could.
vette
I do know that for fact. I have at least 3 personal friends who are mechanics, one in a dealership, and two who own private shops. They think I am nuts for waisting my time doing bleeding when I need to change a caliper.
Yep boiling would make the pedal go down. It also would make the fluid flow when you disconnect the pipe. Fluid running out the pipe would be a good thing. That way no air getting in. If then attached to a fully filled caliper not much air if any would get in. As long as the reservoir didn’t get too low.
Roger
Bronze
I saw what they did in the movie, but that's not what happened in fact. Fancy that, the movies inventing stuff!
Of course, we all know private shops and dealers would never take shortcuts on jobs they do all the time, right? If someone opened up my brake system and didn't bleed afterwards I would never use that shop again; just because you can get away with it 999 times out of a thousand doesn't mean it's the proper procedure (and the plaintiff's lawyer in a lawsuit would bring it up if there was an accident involving the brakes, and you wouldn't want me on the jury).
How often do you swap out calipers? I've had mine off once in 35years/145K miles for rebuild--that I can recall, at least--but I've had to replace several clutch and brake cylinders. The job just isn't done that often, you've got the car up on jackstands or a lift with the wheels off, why wouldn't you take 20 minutes to bleed/flush the system while you're at it? All the shop manuals I've read, for several makes, specify a complete fluid flush every 2-3 years. That may be overkill but you can't say it's a bad idea; DoT 3&4 are hygroscopic--they absorb atmospheric moisture readily (read the label on the bottle)--and DoT 5 causes moisture to pool in the low spots. Suspension and brakes are no place to half-ass a job; if the engine doesn't start you don't go, but if the brakes fail you don't stop.
In the movies or on the track, you might get away with a somewhat softer pedal for a few miles; it's a calculated risk. Not worth it on a 'family' car.
AngliaGT Saw These Today (This is FORD Country?) Spotted 2
AngliaGT '64 Ford F100 Spotted 2
AngliaGT 1969 Ford Galaxie Spotted 3
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 How about an English Ford Folder FORUM Navigation Questions 1
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
AngliaGT New Supra,BaT Ford Bronco Spotted 0
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
C Ford pre-crossflow valve train Other British Cars 2
AngliaGT My Old Ford Consul Capri Other Cars 0
Basil Ford Tractor Spotted 12
O Ford Cars Other British Cars 18
C Wanted Wanted - Ford Cortina "bullet" style gearbox Other British Classifieds 1
H Ford T9 5 speed question Restoration & Tools 1
3798j Ex-Bell Telephone "55 Ford F100 Other Cars 8
C For Sale AC Bristol with a Ford engine Other British Classifieds 0
M TR2/3/3A Ford Alternator Conversion Problems Triumph 10
Paul_1 Vintage Ford Cortina Spotted 12
Steve Ford Capri Spotted 13
PAUL161 6.0 Power Stroke Ford Truck Other Cars 4
D Mazda 3 vs Ford Focus Other Cars 5
aeronca65t Glider in store-Ford GT, etc Spotted 1
P Wedge Ford powered TR7 Triumph 5
Sherlock Ford Sierra RS Cosworth Spotted 1
jackq 47 Ford 2 dr Deluxe Other Cars 4
DrEntropy 1963 Ford Fairlane Spotted 1
G Ford F250 Other Cars 13
mailbox Ford power steering pump Other Cars 0
C Ford 1500 Kent pre-crossflow mystery Other British Cars 16
C Ford 1500 Kent Pre-Cross Flow Mystery Lotus 20
bcliff Ford Model Y English for sale Other British Cars 1
aeronca65t Ford GT Spotted 7
JPSmit Lotus Formula Ford Racecar Other British Cars 2
jackq 46 Ford...finally Other Cars 11
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
A Ford GT Spotted 2
kylekoehler 1953 Ford Consul burned piston Other British Cars 9
J Another pic of '67 Ford GT MKIII Other British Cars 13
J Ford GT MKIII Other British Cars 0
glemon 800,000 ford truck Other Cars 9
CZ_Dave Help in Identifying this British Ford? Other Cars 11
bcliff For the English Ford Lovers Other British Cars 11
tr6nitjulius TR5/TR250 FYI: Ford Blue 250/6 Triumph 12
J Brakes for a Mk2 Ford Cortina Other British Cars 4
