    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
STP versus Purolator oil filters
BritCarFan
I recently bought a STP oil filter (no. S2995). Today I was in the store where they had a sale on Purolator filters. After coming home, I compared the two and noticed that the Purlator (no. L30381) was taller by about a half inch. The filter and gasket diameter are the same.
Won't you have less filter surface area if the filter is shorter?
Yes BCF, that is generally true . However, 1/2" difference isn't that significant. ---Fwiw--Keoke
Provided the filter media inside the can is larger on the longer filter, yes. No guarantee that it is, though. The shorter filter could have more pleats in it. The only way to know for sure is to cut both of them apart and check.
Jeff
Based on a study of Oil filters I read a while back, in which filters of all brands were opened and compared, the Purolator is the better filter. STP came down the list in the test with a pretty bad rating.
I recently learned that K & N is now offering Oil Filters.
If they are as good as their Air Filters, (I use a K & N Air filter in my '84 XJ-6 and the horsepower difference was very obvious and inmediate), I plan on using K & N oil filters. The thing is that K & N can be trusted when it comes to quality and the claims they make, unlike the mass-merchandisers who want to sell a million-filters-a-week, if you know what I mean.
Ex
K&N has had oil filters for quite awhile.
I just use the NAPA Gold filters. Made by Wix. I'd probably use K&N's if they were readily available, but now all my vehicles have the Wix filters on them.
Jeff
OK its my turn. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif Wix filters were formerly built by Dana they are now built by Affinia group new owners of Wix.---Keoke--?
Yep, /bcforum/images/%%GRAEMLIN_URL%%/iagree.gif and they headed for India and China next year.--Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Exotexs said:
yeahh, just imagine, fuel filters with Lead.
Yep might help the petrol but gonna kill the driver and stove up all the bearings!---Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
P.S. I wonder what happens when you get curry ina oil?
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 6
K STP oil additive between changes? Triumph 17
Lin Ford Versus Ferrari Question Austin Healey 23
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
S Ribcase versus Ribcase Spridgets 1
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
D TR2/3/3A Patching, versus replacing floors? Triumph 15
S Points versus Pertronix Spridgets 22
S Idle Speed Setting versus Generator Output Spridgets 3
DanLewis AN5 versus AN5L Spridgets 10
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
P Tachometer versus lights Austin Healey 5
F BN2 versus later seats Austin Healey 6
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
K TR2/3/3A TR3 9" versus 10" Brakes? Triumph 8
racer_x Wedge TR8 Headers: Rimmers versus Woody/TSI Triumph 34
G Texas Cooler Versus Flex Fan Austin Healey 20
steveHealey3000 Originality versus performance Austin Healey 38
bighealeysource Redline versus 20w50 for trans on BN6 Austin Healey 7
bighealeysource original versus replacement bumpers Austin Healey 4
svtmikey Metalastic versus generic Roto-flex couplings Triumph 5
N Ported versus manifold vaccum. Spridgets 31
fad64b Bonnet Steel versus Aluminum MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
D Weber versus twin SU's British Motor Corp 1
2wrench Cam degree wheel versus protractor Triumph 11
2wrench New versus core and rebuild versus running used?? Triumph 5
Newkie PPG versus Dupont MG 24
S Flywheel versus pilot bush Triumph 10
Michael Oritt Guages--mechanical versus electrical Racing 31
Daimlerdb18 Timing light timing versus static test lamp MG 7
fmichaels old harware versus new Spridgets 22
Steve_S Falcon SS versus Peco HDR MG 23
J BJ8 versus BT7 Shroud Austin Healey 11
M Side versus rear exhaust Austin Healey 24
G Midget versus Beetle Cabrio Spridgets 5
jaybird Mike's Midget - or Midget versus semi MG 4
tr6web Brake versus clutch fluid Triumph 14
I GY versus V3 needles in SU carbs Spridgets 1
C Pertronix versus Crane ignition kits ? MG 7
Basil New Mini versus old mini video British Motor Corp 0
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
af3683 TR2/3/3A Original Purolator Oil Filter Canister Triumph 6
TR3MT TR2/3/3A Purolator Oil Filter Leak Triumph 10
T TR2/3/3A Is it a Purolator or Tecalemit? Triumph 5
H Purolator oil pressure relief spring Triumph 1
K Oil pressure or balance valve on top of Purolator Triumph 1
