TR2/3/3A Recommended Oil Filter Cartridge for Purolator
af3683
I'd appreciate knowing what oil filter cartridges folks currently recommend for use on their TR3/TR3B with the original Purolator Oil Filter Canister. I've been using the Classic Gold but I think they are no longer popular. I know some use Wix 51302 or NAPA Gold 1516. I checked a few auto parts websites as well as Amazon for the Wix 51302, and they said that it does not fit a TR3B. Any help would be appreciated. Thanks.
Art
2002S2000
1960 TR3, I used the Wix 51302, just changed oil and filter in October, I purchased the filter on Amazon in summer 2023. I had used the same filter in 2021.
CJD
Usually Wix...because I trust Wix filters and they are readily available at O Reilly's and Auto Zone.
af3683
af3683
The Wix website states that the #51302 oil cartridge comes with 3 gaskets (see below). Can anyone tell me which one is best and how to identify it with the naked eye? I assume they are not color coded.
Gasket Diameters:
Number​
O.D.​
I.D.​
Thk.​
15434 Packed3.375 (86)*2.937 (75)*0.203 (5)*
15122 Packed3.156 (80)*2.916 (74)*0.125 (3)*
15149 Packed3.078 (78)*2.906 (74)*0.175 (4)*
Also, is it true that the NAPA Gold 1516 is made by Wix ? Should I avoid the Classis Gold ?
Thanks.
Art
CJD
The important thing is to be sure to remove the old gasket from the groove in the filter head. Use whichever one that will fit easily into the groove in the head. The advantage to canister is you get to easily look over the filter for metal. I used to think it was messier, but after changing it for a couple decades, I find the spin-on just as messy.
mctriumph
And yet there was a day,(1969) that the new seal blew out and I oiled all of Sean st. The upside was
the front suspension didn't squeak for a year.......
Mad dog
vintagemechanic Recommended clutch kits Jaguar 3
J TR6 Tire Recommended for TR6 Triumph 3
Csarneson Seat Foams and recommended interiors? Austin Healey 13
T TR2/3/3A What air pressure is recommended in my Hoosier tires? Triumph 1
C Recommended reproduction wheels? Austin Healey 29
M Engine Stand - What Bolts Recommended for 948 Spridgets 3
W TR6 Dashboard Recommended finish Triumph 5
GTP1960 TR2/3/3A Recommended brake fluid for a 3A? Triumph 16
MikeAH100M FYI - Hardie Board for Heat Shields not Recommended Austin Healey 9
C TR4/4A Recommended Books Triumph 8
R BJ8 with Servo, Is the 7/8 Master Cylinder recommended ?? Austin Healey 7
6 Recommended clutch slave cylinder pushrod clearance Spridgets 6
60TR3A What's The Recommended Stainless Steel Exhaust for '63 BJ7? Austin Healey 5
RickB Recommended seller of Spridgety bits Spridgets 4
I Recommended lubricant/fluid questions for 948 Spridgets 8
PatGalvin Engine Improvements Recommended? Triumph 6
T MGA Recommended order for building MGA front susp MG 1
T Recommended fuel pressure Spridgets 32
CinneaghTR Recommended Paint Shop near Baltimore, MD? Triumph 8
CinneaghTR Recommended Paint Shop near Baltimore, MD? Restoration & Tools 0
angelfj1 Recommended Lubricant for Lucas Windscreen Wiper Restoration & Tools 4
jjbunn Driving on two wheels - not recommended. Triumph 51
T manufacture's recommended fluids Jaguar 1
2wrench Hylomar recommended, but hard to find. Triumph 14
B Recommended Rover Reading Rover / Land Rover 1
B Recommended Reading MG 5
vping Recommended Spark plug gap MG 26
Ed_K Recommended break in for rebuilt engine ? Austin Healey 7
R Recommended Tire Size? Austin Healey 5
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
