What oil for Datsun 5 speed?
Bayless
I have something that states GL-4 75W90 but don't know its source. What I found a the local parts store today was GL-5 synthetic. If the 75W90 is correct, will the synthetic GL-5 be all right? I'm hoping someone who has one will know what to use.
PAUL161
No, don't use it as GL-5 synthetic reacts with Bronze parts. I would never use it in an older standard shift transmission, Use what the manufacturer recommends, it's out there.
mezy
I can only speek from mazda, they recomend the GL4 75W90 and it is stated that if you use GL5 it makes the gears a lot stiffer to select.
Bayless
Bayless
Thanks mezy. I thought I remembered something about staying with the GL-4 but I can't seem to find it now when I need it (well almost ready). So now I have done a little more research that I should have done before asking. It seems that most GL5 oils contain an additive (sulphur?) that deteriorates the yelllow metal (brass?) in many gearbox synchros. So GL4 it is then even if a little harder to find.
drooartz
I found something from Royal Purple that was a GL4 and the right weight the last time I did a trans fluid swap in my 5-speed Minor. Think I may have found it at my local parts store.
Redline makes one as well:
> MT-90 75W90 GL-4 Gear Oil <
twas_brillig
I use Red Line MT-90 75W90 GL-4, per their recommendations. Doug
Bayless
Bayless
Thanks guys. I got the Royal Purple at Autozone.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
V Oil capacity of Datsun gearbox Spridgets 1
V Datsun gearbox: what kind of oil do you use? Spridgets 10
msoylemez datsun 210 trans oil capacity Spridgets 4
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
NutmegCT Oil comparisons Restoration & Tools 2
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
