Oil comparisons
NutmegCT
Lots of commentary and comparisons on forty oils, with emphasis on zddp.
Interesting note: some findings show zddp may actually increase engine wear.
Tom M.
prb51
It depends upon the test too...what were the testing parameters? My own simple test is cutting open oil filter canisters for particulate matter.
LarryK
I use premium oil, Castrol or Royal Purple. No zddp, except n new break ins, for valve and cam replacement. If I race or track a vehicle older than 73, I will add zddp only on occasion. Any of my high mileage cars never showed much wear.
D T-Series MGTD Oil Leak? MG 1
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
Celtic 77 MGB 77 MG B oil cooler MG 5
KVH General Tech Oil Pump Woodruff Key Triumph 10
prb51 Oil Viscosity Austin Healey 10
A MGB Oil pressure MG 9
Gliderman8 TR6 Would you change oil? Triumph 5
af3683 TR2/3/3A TR3 Purolator Oil Filters Triumph 7
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
KVH General Tech Gaskets—Head/Oil Pump Triumph 4
L Oil Pumps Austin Healey 6
