Datsun gearbox: what kind of oil do you use?
V
vagt6
Wondering what brand/viscosity of gearbox oil that's used by you folks whose Spridgets may have the Datsun B210 gearbox.
I'm gonna drain and refill mine, just wondering what everyone uses.
Thanks!
V
vagt6
AND, while I'm at it here, what brand/viscosity, etc., differential oil do you use.
I'm on a roll, ain't I? :crazy:
RickB
Don't know what the people here will say but the people over on the Datsun forums have very strong opinions.
They say anything too modern will ruin the syncros and that you run the risk of leaks developing if you use synthetic.
80w90 gear lube GL4 but not GL5.
Here's a thread I started over there back in January:
https://forum.ratsun.net/showthread.php?t=9184&highlight=80w
BuggerAll
Synchromax synthetic in the tranny, Royal Purple 80/90/140 in the final drive. As to the former - no leaks, smooth and quiet operation (I did rebuild the tranny before installation, all new bearings and seals, swapped the synchors around to get the best ones on 2nd and 3rd).
RickB
Most of the people I've heard talk about leaks say that it's the old seals that can't take the synthetic and putting in new seals before installing the box is the way to go.
V
vagt6
I contacted Cason Racing in Raleigh, the shop that installed the Datson box in my Midget. He recommended Redline MTL or MT 60.
Said he used MTL in his racers and street cars, excellent results.
Sounds good to me.
Thanks for all the replies, guys!
nomad
Half GL5 80w90 and half GL1 140 wt. Datsun manual says to quiet your gearbox run heavy weight gear oil. I believe in warm temps there is no problem with straight 140. My mix is'nt enough. My tranny needs a overhaul!!
KA.
V
vagt6
Well, here's an email reply I received from a proven speaker of sooth, Will Perry of Rivergate:
<span style="font-style: italic">I suggest a full synthetic gear oil likr Mobil One or Valvoline in the Datsun 210 transmissions. The same oil works good in the differential also.
Thanks
Will Perry</span>
He would know. :yesnod:
Bayless Started adapting the datsun gearbox today Spridgets 46
N Best lube for a Datsun gearbox?? Spridgets 6
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
V Oil capacity of Datsun gearbox Spridgets 1
middie Datsun A12[S] motor * gearbox into a MkIII midget Spridgets 20
J datsun gearbox lever in bugeye Spridgets 7
A Datsun gearbox parts in UK? Spridgets 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
Boink Datsun 2000 Spotted 5
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
shadowfever Datsun 5-speed info neede Spridgets 5
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
K TR2/3/3A Datsun 240Z aluminumn brake drums? Triumph 5
Marvin Gruber Datsun 2000 Other Cars 12
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
P Datsun 510 Other Cars 3
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
jfarris Datsun 1200 Pickup in Alice Springs Spotted 0
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
2 General TR TR6 VS Datsun 240Z Triumph 2
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
T Pressure plate failure on BE with Datsun 5 speed Spridgets 8
histerical Datsun tranny help please Spridgets 18
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Rut Datsun 5 speed Spridgets 24
T Shifter Cupola for Datsun 5 speed Spridgets 19
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
T problems installing 1275/rivergate/datsun in BE Spridgets 25
bugedd Datsun 210 Trans Question Spridgets 9
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
T datsun 5 speed locking up - circlip problems?? Spridgets 0
PC Datsun roadster Spotted 0
abarth69 Innocenti C Datsun 5 speed install Spridgets 21
T Datsun 5 speed locked up Spridgets 7
RickB Datsun 210 with manual transmission $500 Spridgets 0
aeronca65t Datsun 2000 / SRL311 Spotted 3
RickB 65 Midget on craiglist Seattle - 'comes with datsun 5 speed' [nfi] Spridgets 12
RichBall Datsun shift levers on ebay Spridgets 0
C 1981 Datsun 210 for $900 Spridgets 6
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
