New versus core and rebuild versus running used??
2wrench
It's either a blessing or a wolf in sheep's clothing,
but here it is...and I don't have pics.
Came accross a '72 while looking for good cores.
Seller seems to be a nice fellow who tinkers with
different cars. He owns two MGB's and came into
possession of this '72 TR.
Says the engine runs so well that he wouldn't
even suggest a rebuild, just pull it and swap.
Says only thing I can do to determine its viability is
a compression test.
My first visit to take a look-see I popped in because
I was working in an area he lived. Battery was weak
and car wouldn't turn over. He still stands unwavering
the engine is a good runner.
Going back tommorrow morning for a redo. Taking a
fully charged battery (he says cool idea).
Seller says he will perform a compression test and
says to note the oil pressure.
Car has an overdrive tranny and engine and tranny is being offered for sale as a unit.
Anything I could/should ask or do in considering
this purchase for my '74 TR6?
Feedback is appreciated.
NutmegCT
Paranoid Tom thinks it would be a good idea if you do the compression test yourself, as well as check the oil pressure. Etc. Etc.
Unless you know the guy pretty well, and live next door, and get a money-back guarantee in writing.
If you're getting an engine only, the engine only shouldn't hold major surprises. Like my buddy who got an MGA 1275 "no problems - it runs like a dream!" and found all the bearings were shot, the crank warped, and the head cracked.
Just my 2¢
Tom
Brosky
Caveat Emptor, "Let the buyer beware".
You may have a great deal, you may not. I won't really know if my newly purchased spare engine is any good until I pull it apart in the spring.
If you are going to the trouble of pulling it and can afford the costs, now is the time to do it right once and for all.
I'm hoping, but time will tell.
You do have the benefit of the O/D, which is valuable on it's own.
TR4nut
And since you'll be there you should be able to do a quick check on thrust washer health.
I'm not sure you mentioned price in the other threads (and you don't need to) but I'm of the opinion that price rules this - if the price is low enough, what risk are you taking? As a 72, I think that would be an A type tranny and people pay over $500 for them completely untested, and around $1000 or more if they are know they are good.
If the seller is looking for something like $1000 for the combination, I say get the compression numbers, smile, and pull the trigger on it. Just my opinion.
Randy
TR3driver
Great Pumpkin - R.I.P
/bcforum/images/%%GRAEMLIN_URL%%/iagree.gif Unless the price is good enough that you don't care. Even friends sometimes make mistakes, right Chad ?
Lin Ford Versus Ferrari Question Austin Healey 23
H TR4/4A Original TR4a grill versus aftermarket Triumph 0
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
Michael Oritt Spridget Differential Carrier--early versus late question Spridgets 1
S Ribcase versus Ribcase Spridgets 1
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
D TR2/3/3A Patching, versus replacing floors? Triumph 15
S Points versus Pertronix Spridgets 22
S Idle Speed Setting versus Generator Output Spridgets 3
DanLewis AN5 versus AN5L Spridgets 10
DanLewis Oil cooler hose fittings - 5/8 UNF versus 3/8 NPT Spridgets 2
P Tachometer versus lights Austin Healey 5
F BN2 versus later seats Austin Healey 6
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
K TR2/3/3A TR3 9" versus 10" Brakes? Triumph 8
racer_x Wedge TR8 Headers: Rimmers versus Woody/TSI Triumph 34
G Texas Cooler Versus Flex Fan Austin Healey 20
steveHealey3000 Originality versus performance Austin Healey 38
bighealeysource Redline versus 20w50 for trans on BN6 Austin Healey 7
bighealeysource original versus replacement bumpers Austin Healey 4
svtmikey Metalastic versus generic Roto-flex couplings Triumph 5
N Ported versus manifold vaccum. Spridgets 31
fad64b Bonnet Steel versus Aluminum MG 4
S MGA MGB engine versus original in 1957 MGA Coupe????? MG 17
D Weber versus twin SU's British Motor Corp 1
2wrench Cam degree wheel versus protractor Triumph 11
BritCarFan STP versus Purolator oil filters Jaguar 10
Newkie PPG versus Dupont MG 24
S Flywheel versus pilot bush Triumph 10
Michael Oritt Guages--mechanical versus electrical Racing 31
Daimlerdb18 Timing light timing versus static test lamp MG 7
fmichaels old harware versus new Spridgets 22
Steve_S Falcon SS versus Peco HDR MG 23
J BJ8 versus BT7 Shroud Austin Healey 11
M Side versus rear exhaust Austin Healey 24
G Midget versus Beetle Cabrio Spridgets 5
jaybird Mike's Midget - or Midget versus semi MG 4
tr6web Brake versus clutch fluid Triumph 14
I GY versus V3 needles in SU carbs Spridgets 1
C Pertronix versus Crane ignition kits ? MG 7
Basil New Mini versus old mini video British Motor Corp 0
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
HighAltitudeTR3 T-Series Why are there nuts in my core plugs?! MG 8
C Testing heater core Austin Healey 9
RAC68 Radiator Core Replacement and Sleeve Thermostat Alternatives Austin Healey 20
I Weeping Core Plugs Austin Healey 6
T TR4/4A Core Plug - Cam Rear change Triumph 7
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
