TR2/3/3A Crankshaft Thrust Washers
Philthytoo
Member
Hello All,
I'm starting re-assembly of a TR4 engine, and have a couple questions about thrust washers. The standard thickness is .092", but I'm measuring .054" of endplay without any washers installed. Do I buy standard thickness washers and shave nearly half their thickness, or buy +.008" washers and only put one side in? Does there need to be washers on both sides of the bearing cap for proper wear?
Thanks, Phil
TR3driver
Great Pumpkin - R.I.P
Yes, have to have two half-washers per side, total of 4 pieces. IIRC the crank hits something else, so motion measured without washers installed doesn't mean much.
Try measuring with your old washers installed, then measure how badly worn they are.
Or just order two sets of thrusts, they aren't that expensive. Not uncommon to need one pair oversize and one pair standard anyway (the book only gives a .002" range for end float but the oversize washers are .005" thicker).
CJD
During my rebuilds I have always had to take a few thousandths off the washers to get the clearance right. Half would be too much, though!
P
Philthytoo
Member
As usual, if something is really off it's because I screwed something up. The original thrust washers apparently got left at the machine shop, and that business closed a few days after I picked up the motor. So my measurement was with no washers installed, leaving the crankshaft movement to stop as it contacted the block. Looking at it again I realized that there is a recess machined for the washers to set in. So if I read my calipers right and my math is OK, the standard .092" washers will be .0005" too thick. I think taking 1 or 2 thousandths off each side will not be a problem.
I had left the bottom end for the shop to take apart, and didn't think to look for the thrust washers when I picked it up. Every engine I've worked on had thrust controlled by lips on the main bearings.
Thanks for the comments!
Phil
CJD
It could have been worse...I have several friends who lost whole engines or cars when a business closed the doors!
J TR2/3/3A Crankshaft thrust washers. Triumph 2
H Crankshaft Thrust Washers Austin Healey 2
Tinkerman TR2/3/3A Crankshaft thrust washers, 60 TR3 Triumph 6
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
mctriumph TR4/4A Busted crankshaft Triumph 6
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
Gerard 1098 10CC crankshaft Spridgets 14
