TR6 Dash Pad Replacement
EWD
Morning Folks -
Getting ready to install my new dash pad. It would appear that the vents and windshield molding should hold it in place without using adhesive. Any current thoughts before I jump into this?
Thanks,
Will
Geo Hahn
I just used a spray on adhesive applied lightly. This assured things stayed in place during the windscreen frame install, etc. A light application will allow repositioning yet immobilize the piece while you work.
You're right, once the vents and windscreen are on there it isn't going anywhere.
EWD
EWD
Thx guys. Just returned from the paint job. Car finally in progress. My garage is full of parts just waiting for their home.
Best -
Will
E Wanted wanted Austin healey 3000 adjustable steering wheel & dash pad Austin Healey Classifieds 2
S TR4/4A Dash Pad Triumph 3
Griz Dash Pad Austin Healey 8
JimTR4 TR4/4A Top dash pad vinyl is "puffy" Triumph 2
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
M TR4/4A Left lower dash crash pad. Triumph 5
BOBBYR BJ8 top dash pad removal Austin Healey 9
H Dash Pad Clips - BJ7 Austin Healey 3
tomshobby installing new dash pad Spridgets 10
R Dash pad question Spridgets 7
M dash pad? Triumph 5
davidb Austin Healey BJ8 dash pad removal Austin Healey 6
Stinger TR4/4A Quality TR4A Dash Pad Question Triumph 4
J TR4/4A TR4 reproduction dash pad Triumph 3
S BJ8 Dash Pad Austin Healey 7
B Dash Pad-less Austin Healey 18
Brosky Dash pad installed Triumph 20
R Dash Pad Removal Austin Healey 13
6 Please say it's easy...Dash pad removal Austin Healey 4
D Dash Pad Austin Healey 2
V XK150 dash pad Jaguar 2
TR674 Crash Pad [dash top] Triumph 3
B TR4/4A installing TR-4 upper dash pad Triumph 2
R6MGS MGB MGB Dash Pad MG 8
P dash and crash pad Triumph 3
R Remove the dash pad Austin Healey 6
Cain Upper Dash Pad Triumph 9
Paul Slice MGB VB MGB Dash Pad kit MG 4
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
J Spitfire No start after fiddling with dash Triumph 2
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
K TR2/3/3A Switching to green LED dash panel bulbs? Triumph 3
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
KVH General TR Green Turn Signal Dash Indicator Triumph 8
timsgolf Center Dash Switch Plate Painting Austin Healey 5
C MGA Dash removal MG 0
C For Sale BJ8 original dash Austin Healey Classifieds 3
rjc157 For Sale Dash Austin Healey Classifieds 1
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
M MGA RHD MGA dash finisher MG 0
A MGB MGB dash painted MG 13
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
jfarris TR2/3/3A Removing choke cable from dash insert Triumph 3
BoyRacer Blue Vinyl Dash Material Austin Healey 3
jfarris TR2/3/3A Dash Lights Triumph 3
R Ground wires under dash Spridgets 5
EWD TR6 74 TR6 Renegade Dash Wire Triumph 7
B TR4/4A Dash Color? Triumph 3
EWD TR6 TR6 top dash trim paint Triumph 2
