TR4/4A TR4 wood dash
Rut
I have a stack of TR4a and TR6 wood dash’s and since I’ve been on a furniture refinishing rampage I decided to start on one. Much to my surprise the one I selected is a TR4 dash which is much thinner and it has a one piece face unlike the TR4a and TR6 which are bookended. This is an original dash with the heavy coating of “I can’t remove it” (which has been removed), number stamp, dark brown paint, etc. Do y’all run into these one piece dash faces often?
Rut
for some reason the picture will not upload.
TomMull
My Herald has a one piece mahogany (or what appears to be mahogany) veneer. It's fairly straight grained. Usually the only ones that were bookmarked are the more heavily figured veneers. There is little reason to bookmark the straighter veneers.
I used heat to remove the walnut burl veneer on my Lotus.
Tom
charleyf
I have a TR4 CT20000 with an original wood dash. It is a single piece of wood. Likely mahogany.
Rut
Rut
I’ve got a lot of veneer left from other projects and I’ll finish 4 dashes, 2 in straight grain and 2 in burl walnut. What I’ll do with them is anybody’s guess.
Rut
Would only load 1 picture this time.
TomMull
The piece in the picture that came through is not a burl but a highly figured veneer of what appears to be black walnut. It's a lovely piece and will make an interesting dash. It is not a burl though. You still might want to bookmark the piece to keep the grain symmetrical on both sides. Not hard to do but it does complicate things a bit. The ripples in the grain are a bit of a challenge when you do your veneering. If you run your hand along the surface you can feel the ripples. Humidity changes make it worse. The water in most glues also raise the grain. (hide glue does not but that's another story).
Burl wood is quite different. https://en.wikipedia.org/wiki/Burl
It does not come in long pieces and pieces much over about three feet become very expensive. Symmetry and expense both play a part in bookmarking burl veneers.
Feel free to check out my post on the Lotus veneer in the Lotus forum.
https://www.britishcarforum.com/bcf/showthread.php?119335-replacing-walnut-veneeron-the-dash
Keep us posted on your work too.
Tom
Rut
Rut
Tom,
The burl picture did not come thru, but you can see part of the burl in the upper right of the picture that did post.
Rut
TomMull
Tom,
Rut
Yes, quite clearly seen in this picture. Do you have bookmark cuts (2 pieces) of this veneer or will you do it in one piece?
Tom
Rut
Rut
Tom,
I have 6 pieces that could cover 3 dashes if not more. I’m leaning toward using the figured walnut for a TR6 dash and saving the burl for another project/dash.
Rut
RJCOX
Rut,
How does the wood veneer/plywood dash attach?
Mine is desperately in need of help.
She just arrived today
Rut
Rut
RJCOX,
Wow, that TR looks like something I would drag home! Steering wheel looks like a factory upgrade and they are pretty rare as I understand it.
The dash unscrews from the metal dash support, but you need to pull the gauges first. The walnut has delaminated and I hope the base plywood is ok. If it’s started to come apart you will need to repair it first, prep the plywood and paint the backside. A dark brown paint is used along the edges of the vents and glove box door and opening and I find it easier to paint those before I finish the dash. If the plywood is really shot, pm me to discuss options. The rest of your car needs a lot of help with rust removal and new metal welded in. Good luck on your project!
Rut
RJCOX
Yeah, been there on rust repair. My 3 had (and my dad's 3) had some issues with rust. Did floors and inner and outer sills on mine and the front cowls on both as well.
I've done my share of woodworking but never veneer. I read through a bunch of your posts but didn't see how to remove the dash/wood, but your methods are inspiring. I'm actually excited to get to it.
Sadly, I think the plywood may be damaged beyond repair. I'm hoping that I can get a good pattern at least. I'll most likely bug you for guidance on best materials to replace it.
Thanks for reaching out!
Ron
TomMull
Tom,
Rut
The Lotus dash is a bit odd requiring a piece 18 x 44 inches, which is why a did bookmark. Walnut burl in that size is available but $150 or more.
RJCOX, A new dash is easy to make if you have enough of the old one for a pattern. Use a trim router with a 1/4 inch flush bit. A plunge bit makes it even fasted. Mine dash was 7 ply aircraft spruce, not available today as far as I know so I went to some pains to stay with the original.
They are usually held in by a few bolts.
Tom
RJCOX
I hope to have enough material to get the pattern.
If I'm really lucky, a re-veneer.
Assuming its just the veneer, what kind of surface prep can I look forward to or what should I avoid doing (i wont be using a palm sander). Any paints or sealers that I should use on the gluing surface?
TomMull
Imperfections in the plywood dash can show through the veneer and little voids w may cause issues later. After taking off the original veneer with a sharp scraper and a heat gun, used carefully, I simply hand sanded the plywood with a 1 foot block and 220 sandpaper. My dash didn't need much but I filled the few little voids it had with bondo. The plies on mine were super thin so I was not very aggressive with the sanding. Essentially prep as though you'd be painting it.
The glue I used, (Titebond ironed on) sticks very well to bare wood, no primer of any kind necessary.
Tom
Rut
Rut
Tom offered very good advice and I’ll throw in some more. Hobby shops have basswood in different thicknesses, so you can rebuild your plywood and make sure all of the laminations are still stuck together. I like to use a veneer glue that’s tinted to the finished product so you won’t have imperfections show thru from a ‘yellow glue’ when staining or finishing. I think a glue roller is essential for a smooth finish along with a veneer softener, especially if you decide to go with a burl which is notoriously brittle and lumpy.
Im currently working on several dashes, but got sidetracked by my sons International Scout which needs everything. If your dash ends up being trash, just let me know and I can send you one to swap out. It’s going to be awhile before you reach that stage, so we have plenty of time...just let me know how light/dark and gloss/satin you want the finish to be. I’ve gotten into wood dye vs stain as of late and I’m going nuts with the stuff as I learn more about it.
Rut
Rod-H
Bronze
+1 on wood dye, I've been using it since I started making guitars 25 about years ago.
From the stewmac webpage (these are actually dyes not stains): https://www.stewmac.com/luthier-too...nishing-supplies/colortone-liquid-stains.html
I've had good experiences vacuum bagging for veneering. You don't need a bunch of fancy equipment to do it, A shop vac, some stretchy plastic, some tape, and some dark beer.
Rod
Popeye
Bronze
A few thoughts:
1. Veneer and finish on both sides, otherwise the wood may warp. Obviously surface finish is not critical on the backside, but the veneer should be sealed with a few coats of varnish.
2. Marine grade plywood is more expensive, but for a reasonably small piece such as a dashboard the delta is not terrible. It has fewer voids than "normal" plywood, and better moisture resistance in the adhesive.
TomMull
RJCOX
I'm a Guinness fan myself, but reserve it for the end of the day when I'm bragging about my car with the mates, or after playing a set.
Rut, I'll let you know how I fare with the dash removal and what condition the plywood is in.
Tom and Mike, great info. I've got the tools and supplies (well not the veneer) just need to develop the skills a bit. I've got some StewMac dyes already for a mandolin that I am finishing. Single color dash should be easy (to color).
Ron
RJCOX
Well, it looks like an aftermarket dash added on top of the original white dash, but I'm not sure. There's about 8 screws oe more holding it on.
Think I'll take the screws out and peelit back a bit (gently) and see what's back there.
R TR4/4A Recommendations for Wood dash 1962 TR4 Triumph 5
A TR4/4A TR4 A wood glove box door question Triumph 0
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 9
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
