Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Everybody has a recommendation and they are all different. I couldn't figure out who to believe so I went with the guys who made the carbs and bought a bottle of genuine SU branded dashpot oil.
What CJD said. The only thing that didn't work was WD40. ATF, 20w, 30w, 10w-30, 10w-40, 5w-30 any medium grade oil/lubricant will work fine. I have tried many different, unless you go way too thick or way too thin you won't notice a difference.
Not mentioned yet is the reason for damper oil...It's to slow down the rate at which the air valve rises. During that short interval of time, which is really short, the slow response actually enrichens the fuel/air mix which is condusive to smooth acceleration.
ZS carbs, btw, do best with engine oil rather than any real thin stuff...maybe the difference is because of the ZS carbs Air Valve diaphragm's complete sealing of the suction chamber
I just realized that whale oil was still available when these cars were built. Wonder if that would have been a recommendation if we had internet in the 60's?
My Dad used 3N1 oil in his Jag XK140FHC, and his '49 MG TC, I used it in an MGB, TR3B and current TR3B because thats what he used. It may have had something to do with being in Fairbanks with the XK140 (daily driver in '58-59) but it never failed....
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
