Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
So Black Satin it will be. I've never seen a Semi-Flat Trevor.
Oh I love CA Cars. Put TR End in the vise, two tugs with the BF Adjustable Wrench and the big nut spun off. Held the inner rack rod with small adjustable box wrench and put big Pipe Wrench on TRE and after two turns around with assistance it spun off 21 turns later. A good thing
Rut, new TRE is at least 1/4" Deeper in thread depth, adjust to same number of threads left exposed on the big nut as before. It appears outer dimensions are the same just deeper threads.
Jim,
I like to clean them up with sandpaper followed by a phosphoric acid wash, water wash and dry, pre paint prep, prime and top coat x2. Figure out a way to heat the paint to make it hard and Bobs your mothers brother!
Rut
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
