TR4/4A Geez - this head is really stuck on the engine
tdskip
Hi guys - have made zero progress on the TR4a since I have been unable to get the head off the car. Have used lots of penetrating oil, leveraging the intake side of the head with wooden dowel (carefully) into open port, hammering wooden wedges into the seam between engine and head, turning her over with plugs in. Studs don't want to come out even double nutted.
Was wondering about making something that attaches to the rocker shaft stud holes so I can use an engine puller to lift the head up and off. Anyone done that?
Thanks!
DavidApp
Have you got any gap between the head and the block? If you do try wooden wedges. May be worth putting a thin piece of sheet steel on the block so that the wedge does not damage the block.
I had the same problem getting the head off. Studs would not move even after days of soaking. At least my engine was out of the car. Finally got it by carefully banging on the head at various locations and once I had a gap I used wooden wedges to get it off. It fought all the way to the last thing. Cleaned the studs and holes and it goes on easily.
David
Geo Hahn
I think the problem may be that you will just lift the entire car by those studs.
Wish I had a better idea to offer.
T
tdskip
Thanks guys - appreciate the responses.
I managed to get three head studs out on the exhaust side and that did the trick. I found some interesting things - will start a separate thread on that for others to (hopefully) benefit from.
Thanks again.
dklawson
Remove all the studs you can get out. Soak all the studs with lots of penetrating oil (not WD-40).
Remove the rocker gear from the head so all the valves are closed. With the spark plugs removed, feed equal lengths of cotton rope into the bores. Bump the starter a few times. The rope will fill the combustion chambers and two of the pistons will lift the head from below.
T
tdskip
Hi Doug - removing the three studs that I was able to get off did the trick, the other two are stuck for now, but the head is off finally.
Thank you for the follow-up!
TR3driver
Great Pumpkin - R.I.P
Not that it matters now, but I have tried the engine hoist on the rocker stud holes (using bolts, not the original studs). Picked the whole car up that way. Set it down, removed the hoist, picked the head up by hand! It apparently bound on the studs even though it wasn't really stuck at all (I was just trying the hoist to be lazy).
DNK Geez... Triumph 8
D Geez....exhaust do-nutz on a 2.4L! Jaguar 0
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
T TR2/3/3A Water pumps/head cooling Triumph 22
T TR2/3/3A cylinder head ,valves and springs Triumph 0
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
