TR2/3/3A Applying the Permatex copper gasket spray to the head gasket?
Popeye
Bronze
I think I let it cure before installing; maybe 30 minutes. To make sure (1) it does not drip into places it's not supposed to be, and (2) I assumed it needs some thickness to seal, and I applied a few (light) coats. It should "ooze", not run.
The Permatex web page says you can pre-coat, so you can't go wrong with letting it dry. At the same time, the instructions do not include a requirement to let it dry... bottom line it probably doesn't matter.
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
R MINI is applying for heritage status in MALAYSIA! British Motor Corp 2
R Clicking noise when applying brakes Austin Healey 4
S Any advice on applying decals? Triumph 12
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
KVH General Tech Permatex aviation Triumph 2
T General TR How does Permatex Permashield compare to Hylomar for sump sealant? Triumph 5
KVH Best Sealants/Permatex, Hylomar, etc Triumph 14
TRclassic3 Permatex Aviation Triumph 16
G I've got Permatex Aviation Sealant on my Mouse. Triumph 13
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
TomMull Copper nickel lines again Restoration & Tools 0
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
glemon General Tech Nickel Copper Brake Lines Triumph 10
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
NutmegCT T-Series the copper pipe? MG 19
CJD TR2/3/3A Steel vs Copper fig of 8's Triumph 20
K TR2/3/3A Copper fuel line..... Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
S Will copper grease work for squeeling brakes? Austin Healey 3
tinman58 TR6 Copper washer? Triumph 5
DNK Copper in Brake Fluid Other Cars 2
Rut Copper rivets Spridgets 9
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
M brake pipe copper straps Spridgets 19
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
H Re-use of a Copper Headgasket Triumph 7
W Copper fuel lines Spridgets 10
Hairyone copper head gasket Spridgets 5
K Installing Head bolts and copper gasket Triumph 12
heliguy Copper or Copper Nickel Brake Pipes? Triumph 4
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
MTribe special bolt for copper washer on sealing block? Triumph 2
6 Thor hammer restoration w/ copper heads Restoration & Tools 2
Morris Copper spray and head gasket instructions??? Spridgets 5
Steve_S Painting Copper Restoration & Tools 2
PATR8 Wedge Copper [my TR8] is out Triumph 2
davelgee copper head gaskets? Other Cars 2
healeyboz Copper Gasket Spridgets 1
B Copper gaskets for master cylinder, E-Type Jaguar 3
T head gaskets?-copper of steel? Triumph 4
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
V Copper Brake Lines? Triumph 27
G Copper Brake Pipes for MIdget Spridgets 3
C copper brake pipe lengths Other Cars 12
C copper brake pipe lengths Austin Healey 2
Z Copper spray and coated head gaskets? Triumph 0
