Copper or Copper Nickel Brake Pipes?
heliguy
Does anyone know if the brake pipe kits that Moss sells are copper, or are they the copper/nickel ones ( i think they may call them kunifor?)
thanks in advance,
Mitch
Scott_Hower
thanks in advance,
Mitch
Dunno about the Moss kit (ask Tony Barnhill, he'll know) but I think it's CuNiFer (as in Copper, Nickel, Steel composition).
MGTF1250Dave
Aloha Mitch,
Copper tubing, like that used in plumbing does not have a sufficient strength do be used in a hydraulic braking system. The standard steel 3/16 Bundy tubing used as brake lines has a burst string of about 12000 psi. It is a double wall low carbon steel coated with copper, rolled 720 degrees and then welded. Copper nickel alloy (kunifer) tubing is often used as a replacement for steel Bundy tubing as brake lines for corrosion concerns and is much stronger than copper tubing.
As recommended you could either confirm with Tony or Moss customer service if the brake lines are copper nickel or not. I suspect you will find they are kunifer. Perhaps you should recommend the improve the description of the product offering in the catalog.
heliguy
heliguy
Just sent a quick note to Moss to confirm that they are indeed copper/nickel ( Cunifer ) The Moss UK site lists copper/nickel pipes as well as just copper, but copper/nickel is what i want to replace all my old rusty steel ones with.
thanks for the info guys,
Mitch
Scott_Hower
Mitch
FWIW, I have a set of stainless steel lines from Classic Tube and Line. They came CNC pre-bent and fit perfectly. One very happy customer.
TomMull Copper nickel lines again Restoration & Tools 0
glemon General Tech Nickel Copper Brake Lines Triumph 10
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
NutmegCT T-Series the copper pipe? MG 19
CJD TR2/3/3A Steel vs Copper fig of 8's Triumph 20
K TR2/3/3A Copper fuel line..... Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
S Will copper grease work for squeeling brakes? Austin Healey 3
tinman58 TR6 Copper washer? Triumph 5
DNK Copper in Brake Fluid Other Cars 2
Rut Copper rivets Spridgets 9
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
M brake pipe copper straps Spridgets 19
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
H Re-use of a Copper Headgasket Triumph 7
W Copper fuel lines Spridgets 10
Hairyone copper head gasket Spridgets 5
K Installing Head bolts and copper gasket Triumph 12
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
MTribe special bolt for copper washer on sealing block? Triumph 2
6 Thor hammer restoration w/ copper heads Restoration & Tools 2
Morris Copper spray and head gasket instructions??? Spridgets 5
Steve_S Painting Copper Restoration & Tools 2
PATR8 Wedge Copper [my TR8] is out Triumph 2
davelgee copper head gaskets? Other Cars 2
healeyboz Copper Gasket Spridgets 1
B Copper gaskets for master cylinder, E-Type Jaguar 3
T head gaskets?-copper of steel? Triumph 4
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
V Copper Brake Lines? Triumph 27
G Copper Brake Pipes for MIdget Spridgets 3
C copper brake pipe lengths Other Cars 12
C copper brake pipe lengths Austin Healey 2
Z Copper spray and coated head gaskets? Triumph 0
D Copper core plug wires MG 3
mcguijo Zinc or Nickel? Triumph 1
GregW Caswell nickel plating kit Restoration & Tools 3
