General Tech Nickel Copper Brake Lines
glemon
I was trying to make a flare end with a buddy a while back and we weren't having any luck, it would split or crack or go lopsided. I didn't think much of it at the time, and just told home to take the line to the brake and clutch shop and they would fix you up for $5 or so.
Fast forward a couple months and I need to replace about an 100" line running from front to back of my new/ old Ford Ranger. They don't make a line that long and both ends are different, the guy at Advance Auto sells me a roll of this nickel copper stuff (which I have read is softer and easier to work with). I had the same problem as I did at my friend's. I figure it must be the same stuff cause Looks the same and has the same issues. After 3 or 4 attempts of making a decent inverted flare I give up. I ended up finding a coil of steel I had lying around and it worked fine.
Is there a secret to working with this stuff? Working with my cheap tool and the steel line the secret is to camp the **** out of it. Tried softer and harder clamping and slight variations in initial protrusion length with the nickel copper stuff. No luck on getting a decent flare, metal wasn't smooth and or lopsided mushroom? Any tricks to using the stuff?
TomMull
The copper/nickel is certainly softer than steel and there may be different alloys available to complicate even further. It is prone to going lopsided and I suspect the solution to that is getting the initial protrusion perfect when clamped in the tool. Take care with as the alignment of press as well. Use the protrusion guide, usually the edge of the die that comes with the kit. Keep the clamping part securely in a vice if possible. I' avoid on making flares with the brake line still on the car.
I have also found that my slightly imperfect flares worked fine.
Tom
CJD
I learned early on that you must chamfer the inside and outside of the line you are working with. If you are using a tube cutter it leaves a very sharp edge on the ID, which must come off. It takes a decent flaring tool...many are junk and do not stabilize the die as it is compressing. Then, for the first step, compressing into the bubble, you must take care to work rather slow and make sure the die is compressing in line. If you are doing everything right and still getting lop-sided, then I suspect your flare tool is not solid enough.
glemon
glemon
That is good advice, I don't have proper chamfering tools, just a pointy piece of hard steel and some sandpaper.
Sarastro
I've had the same problem, and I use a fairly high-end flaring tool. It's funny that I did my entire TD with that tool and cunifer lines, with no problem. Tthey are all 45-degree double flares. I plumbed my TR4 mostly with steel lines, but I had to do a couple of cunifer pieces, and I had a lot of trouble getting the initial bubble nice and symmetrical--it kept going lopsided. Not sure why I had problems this time, and not earlier, but John's comments might be a hint.
Earlier, I tried doing some flares in cunifer with a cheapo flaring tool, and it was a disaster. I couldn't come even close to obtaining a decent flare.
You might want to see if you can borrow a good flaring tool, or just use steel line. It's a little harder to form, but not really all that bad.
glemon
glemon
I had some old steel line sitting around and used it. The flares look pretty good, should get a chance to check out the seal Wednesday.
TR4nut
I bought Eastwood’s flaring tool that mounts to a bench vice. It’s done very well on cunifer but I did have the lopsided problem with steel. I tracked down my specific problem to the pipe not clamped in strongly enough, at least that seemed to fix the issue.
glemon
glemon
Yes, working with the steel you really need to clamp down hard on the pipe, haven't figured out the trick with the copper nickel. It is back together and working, one of the flares needed a little extra torque to seal. 97 Ranger, had to replace RWCs because one of the bleeders was rusted on. Haven't seen this much rust since I daily drove Triumphs and Healeys in the 70s and 80s.
sp53
Yes tube flaring is a brutal learning curve, no pun intended. I use a small rat tail file to do what John suggested and to get the flare to fold back onto itself after the first step of the bubble is completed. I also take a fine file or small grinder and file that very little bit of a ring on the tip of bubble off, so the fold can go back into itself. If the center section sticks up even a 64th the flare will fold lopsided because of that little small ring that is left on tip of the bubble gives the tube strength. One other thing to watch is the angle of the tool that pushes the flare back into itself because they wear out or have the wrong angle and blow out the flare before it folds.
steve
sp53
steve
heliguy Copper or Copper Nickel Brake Pipes? Triumph 4
TomMull Copper nickel lines again Restoration & Tools 0
mcguijo Zinc or Nickel? Triumph 1
GregW Caswell nickel plating kit Restoration & Tools 3
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
K TR2/3/3A Copper pipe from pump to carbs Triumph 9
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
jfarris TR2/3/3A Which spark lug to use - copper/platinum/iridium Triumph 14
NutmegCT T-Series the copper pipe? MG 19
CJD TR2/3/3A Steel vs Copper fig of 8's Triumph 20
K TR2/3/3A Copper fuel line..... Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
S Will copper grease work for squeeling brakes? Austin Healey 3
tinman58 TR6 Copper washer? Triumph 5
DNK Copper in Brake Fluid Other Cars 2
Rut Copper rivets Spridgets 9
Patrick67BJ8 Copper Drain Lines for BJ8 Carb/Intake Manifold Austin Healey 30
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
M brake pipe copper straps Spridgets 19
bighealeysource Overflow copper tube from carb manifold ? Austin Healey 2
The_architect oil pressure gauge lines: steel vs copper Spridgets 8
H Re-use of a Copper Headgasket Triumph 7
W Copper fuel lines Spridgets 10
Hairyone copper head gasket Spridgets 5
K Installing Head bolts and copper gasket Triumph 12
S TR2/3/3A TR3 Copper Head Gasket -- quick questions Triumph 8
MTribe special bolt for copper washer on sealing block? Triumph 2
6 Thor hammer restoration w/ copper heads Restoration & Tools 2
Morris Copper spray and head gasket instructions??? Spridgets 5
Steve_S Painting Copper Restoration & Tools 2
PATR8 Wedge Copper [my TR8] is out Triumph 2
davelgee copper head gaskets? Other Cars 2
healeyboz Copper Gasket Spridgets 1
B Copper gaskets for master cylinder, E-Type Jaguar 3
T head gaskets?-copper of steel? Triumph 4
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
V Copper Brake Lines? Triumph 27
G Copper Brake Pipes for MIdget Spridgets 3
C copper brake pipe lengths Other Cars 12
C copper brake pipe lengths Austin Healey 2
Z Copper spray and coated head gaskets? Triumph 0
D Copper core plug wires MG 3
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
