head gaskets?-copper of steel?
trfourtune
hi all, why go solid steel head gaskets instead of solid copper head gaskets in modified engines? i can't think of any advantages with steel other than if you have extremely close piston top to head clearance and the slight compressability with copper would run you into trouble. i notice that BFE sells steel ones.
help? /ubbthreads/images/graemlins/crazyeyes.gif /ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/confused.gif
Geo Hahn
I suppose there was a good reason why Superman wasn't called the 'Man of Copper'... but for a head gasket I would think Cu would be the stuff.
The steel gaskets were originally meant to be used in conjunction with the stock gasket to reduce compression in areas of the world where octane was poor... hence they were offered by Standard. But with copper available that would be the way to go if wanting a solid gasket -- goodness knows that some find even the solid copper difficult to get a good seal.
Can I get one for a toyota 3VZE?
Alan_Myers
Hi Rob,
Talk to Ken at BF&E about solid copper head gaskets. He told me he's had a lot of trouble getting them to seal properly. OTOH, the shim steel gaskets are pretty bullet-proof.
dklawson Copper Composite Head Gaskets - Sealant or No? Triumph 6
davelgee copper head gaskets? Other Cars 2
Z Copper spray and coated head gaskets? Triumph 0
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
S TR2/3/3A cooper head gaskets packaged improperly Triumph 6
dklawson Spitfire My Spitfire Mistake - Advice Needed Re. Head Gaskets Triumph 14
PeterK Cometic head gaskets Triumph 4
KVH Payen Head Gaskets Triumph 4
kennypinkerton My Toyota - replacing the head gaskets... Other Cars 133
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
