TR2/3/3A Head Gasket
tinman58
I am doing an engine rebuild on my TR3. Lots of info on head gaskets. I have the 89 mm pistons and the Moss supercharger. I bought some parts already. Including the solid copper head gasket. I have read good and not so good. Any real life experience on good bad or indifferent?
The gasket I have is Moss #387-525 $169.99. or #694-515 $75.99 not really worried about the cost. But which is best.
malbaby
The critical factor is matching the gasket to the 89mm bore.
There is never any guarantee that a replacement gasket will exactly match your block configuration.
The bonus with a copper gasket is that you can trim it to suit the bores etc....cannot be achieved satisfactoriy with a steel or composite gasket.
As a matter of interest, have you measure the combustion chamber volume to ascertain the compression ratio.
mctriumph
Tinman, IMHO you have gone too far , 89mm will NOT have sufficient sidewall strength for a blower.
You will need a broom and a basket when this grenade pops.
Mad dog
tinman58
tinman58
Mad Dog, I have about 15,000 miles on the 89mm and supercharger. Hitting 7 lbs of boost. Yea I ran it hard and was told by Guys smarter than me that it’s a bomb waiting to blow. Well I am getting a little older and maybe a little smarter, so in the future I’ll be easier on the right foot. What are your thoughts on the head gasket?
tinman58
tinman58
Just heard back from the machine shop. Apparently the crankshaft was .20 over . When I got the crank I was told it was .10 over. So that explains low oil pressure and the (noise) . So they are doing a line bore, to go .30 for main and pistons. Cam looks good and the cylinder head and valves are good. fix two broken head studs, shave the head and block.
malbaby
Who assembled the engine?.....10 over bearings on 20 over crank, surely not.
You need to be very careful if you "shave' [deck] the block...Could end up with protruding pistons, and therefore higher compression, or pistons too close to the head.
Piston tops can be machined down to suit, or thicker head gasket.
Recommend measuring the combustion chamber volume before the head shave.
Head shave after testing a piston for protrusion.
Hamish Racing
you May have to tell the machine shop that the wet liners need a constant 3 , 4 0r 5 thou protrusion
I have seen shops used to moderns - deck the block with the liners in place and it’s all “nice and level” which means there will be no clamping force on the fig 8 gaskets at the bottom of the liners.
mctriumph
Tinman, Cometic head gaskets are worth the extra $$(spelling?) ran them on the race car due to the over bore.
Custom pistons would be my next suggestion. I run Vanolia's in my 59 . If memory serves ,some 70 grams
lighter than stock ,but you need to lower your pistons to take advantage of the blower(IMHO) compression
is your enemy on this motor .A little is good, a lot is NOT.I kept the 59 down to 9.1/1 just so I could use a blower.
But it did almost 160 on the engine dyno so it never got the blower. This motor has 35K on it now but when
this girl hits 6800 , You be JAMMIN !
Mad dog
tinman58
tinman58
Opps! crank was under not over.
mctriumph
I have a funny story about smuggling a crank to Honolulu back in the days when they just
took the bags and loaded up NC.
Connected next plane in LAX, and there was a really steep baggage Shute . The suitcase simply
exploded when it hit the stop at the bottom! Had to get a bunch of tape to go on ...
Mad dog
RichB4493
I have a modified TR3 head with enlarged asymmetrical valve openings and polished ports … (Kasner style). Tried a solid copper head gasket trimmed to fit. But it still leaked. Ended up buying Racetorations premium gasket with the sealant beads. Works fantastic. Very expensive but worth it.
I tried reaching Comitec several Times in this endeavor last year but they did not respond from phone or email. Hope your experience is better.
tinman58
tinman58
It's been awhile, But engine is in and running great. Oil pressure was 90 lbs at 2500 rpm's so backed off the pressure to 70 at 2000 rpm's. Very happy with everything so far. It was almost 60 degrees here yesterday so took it out for the maiden drive. Wow sure felt good. Also happy to get the garage back to normal. So next breaking time, retorque the heads and I hope that it will be the last time of major work on the TR3.
tinman58
tinman58
I got the composite head gasket from British parts northwest. Debated about the solid copper one.
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
DrEntropy MGB Head gasket R&R goes on... MG 13
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
R BJ8 Cylinder Head Gasket Austin Healey 38
B TR4/4A Head gasket won't lay flat Triumph 13
Michael Oritt Head gasket question Austin Healey 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Simmo TR2/3/3A Head Gasket Triumph 4
KVH General Tech Head Gasket Triumph 10
RJS General TR Head Gasket Test Fit Triumph 5
D TR2/3/3A head gasket... which way up?! Triumph 8
KVH TR4/4A Blown Head Gasket? Triumph 12
T TR4/4A Head gasket sealer question Triumph 7
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
H TR4/4A Head Gasket Issue Triumph 4
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
T TR4/4A Best head gasket for a 4A? Triumph 12
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
B Victoria British Head Gasket Austin Healey 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
G Payen XK engine head gasket -- which side is the top? Jaguar 2
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
S Tolerance for head gasket Austin Healey 10
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
Gliderman8 TR6 Question on installing new head gasket Triumph 2
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
M TR2/3/3A Head gasket leaking in two places Triumph 13
S TR2/3/3A head gasket Triumph 5
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
O HEALEY 100 Head Gasket Gone ? Austin Healey 10
