TR6 Question on installing new head gasket
Gliderman8
I will shortly be installing an rebuilt head on my TR6.
When putting the gasket down, is it necessary to use any sealer around the water holes, or should the gasket be applied to just the two clean surfaces and torqued down?
I'm concerned about using sealer since that introduces another "level" between the gasket and the block/head.
poolboy
I wouldn't go so far as to say this is necessary...but if you did not have the top of the block resurfaced and leveled, like the machine shop probably did to the bottom of the cylinder head, I'd use this.
I hang the gasket up suspended by a wire and spray both sides with several light coats..It actually makes for a better seal if there are small irregularities in the surface.
https://www.permatex.com/products-2...-copper-spray-a-gasket-hi-temp-sealant-detail
DNK
Coat Hanger...Hanging it up...
Now why didn't I think of that???
K TR2/3/3A Question about installing the steering wheel control head? Triumph 1
M MGB Disributor clamp question MG 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
Celtic 77 MGB factory hardtop question... MG 10
D Cam Timing question. Spridgets 11
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
T TR2/3/3A TR3A Disk Brake Question Triumph 10
JPSmit Distributor question Spridgets 0
Bayless Door seal question Spridgets 3
M T-Series TD/TF Steering Free Play Question MG 6
sail TR4/4A Piston Ring Question Triumph 6
B TR4/4A Basic Wiring Question Triumph 35
KLUTZ Wedge FASD wire question Triumph 1
T TR2/3/3A Brake system question - Triumph 4
drooartz MGB OD question - need to warm up? MG 8
J TR4/4A Sellers Reconcilliation Question Triumph 7
drooartz MGB Question on timing and vacuum MG 11
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
T TR2/3/3A TR3 Fuse Question Triumph 14
B TR4/4A Jaeger Gauge Question Triumph 16
